1969 loose steering
If you have several inches of wheel movement you probably need to adjust the second box adjustment, the worm shaft bearing preload. You'll need to adjust the 2 inch jam ring that goes around the output shaft: This is the adjustment that gets really loose and causes lot of wheel on-center looseness:
Mine was a 1/2 inch loose and took out 4 inches of looseness at the wheel. Just follow these procedures carefully:
http://www.steerco.com/v/webtech/Ste...Adjustment.pdf
Tons more steering information here and here:
http://www.hotrod.com/articles/ccrp-...g-box-upgrade/
http://jimshea.corvettefaq.com/
Jim Sheas excellent page on adjusting your box in the car here:
http://jimshea.corvettefaq.com/?p=810
The bearing preload is probably shot, attempting to adjust it on an assembled box is a waste of time as you won't get an accurate setting, you might think so but it won't be close. On the car lash adjustment has to be done on center or you will over tighten and anything left of the center tooth of the sector will be wrecked in no time.
I am not trying to tell not to attempt it but don't expect much if the box is an original worn out one. It can be made better then new but it will take more then a common bearing kit.
YES...the chances that the original steering gear box is needing to be rebuilt is highly likely.
But even if it was done perfectly by GTR1999. That does NOT mean that your steering will be perfect.
Because the steering gear box is only one part of a the steering system so you still have to consider the condition of:
Control arm bushings, ball joints, tie-rod ends, idler arm, power steering control valve stud and if it does not have power steering the condition of the stud on the center link.
And last but not least is the condition of your steering coupling..sd the condition of the steering column bearings themselves or the pivot housing for your tele-tilt steering if you have that.
DUB
Easy enough to check on the car with a helper. Jack up the car so the front tires are clear, have someone inside and center the steering. The steering wheel spoke should be a 6 o'clock, pitman arm pointing forward, this is the high lash, there should be no lost motion at this point moving the steerng wheel- input motion to the box should move the pitman arm at the same time- only on center, off center will have play.
thanks for all the links. I am reading through it all.
