So - i picked up a 71 that really should be a parts car but i'm saving it.
WHen it sat on the tires, both doors rubbed as they closed.
Its now sitting on jackstands (as all the suspension is out) and voila! the doors close beautifully.
knowing these cars have aluminum bushing mounts, I didn't think "body sag" was an issue on this area.
The back half of the frame has some serious rust issues, but it doesn't appear (yet) that the body mount perches in front of the rear tire have collapsed or anything like that.
I did order straps and am planning to lift the body to inspect, clean, and change (and hopefully not have to replace the frame) but do the aluminum mounts "collapse" like the rubber stuff does?
The frame is flexing when you put it on stands. Flexing back to where it was supposed to be. If mount is shot and frame ok, door gap will stay the same when jacked up.
My 69 was converted to rubber mounts at some point long before I picked it up 12 years ago - maybe yours was as well? I’d also search forum for the DUB recommended way to put our cars up on stands... I’m of the camp that even good rust free frames are overly flexible and can be damaged by being on stands without the front properly supported. This has been a hotly debated talk at times - better to be safe than sorry I think.
As I have stated in many threads that deal with WHERE to put jack stands. I only give my opinion on what I have seen and what I have had to repair when the frame is supported in the manner that GM states.
NEW frames are one thing....but these are aged frames are an entirely different issue. And never knowing the history of the Corvettes I work on...I have employed a method that takes ALL of those concerns out of the equation due to where I place the jack stands....which can change due to what I am doing or removing off the car.
