Chrome Ball Vents
Old Oct 21, 2002 | 10:43 AM
DaddyO's Avatar
DaddyO
Default Chrome Ball Vents
My chrome ball vents are very discolored. How hard is it to change these?
Old Oct 21, 2002 | 10:46 AM
Wrencher's Avatar
Wrencher
Default Re: Chrome Ball Vents (DaddyO)
Mine are junk as well. I had my passenger side panel off, and if I remember correctly, it was a piece of cake. Did you buy a kit, just the ball? Mine needs the *****, felts, and part of the linkage as well.
Hans
Old Oct 21, 2002 | 10:48 AM
DaddyO's Avatar
DaddyO
Default Re: Chrome Ball Vents (Wrencher)
a set of ball and the gaskets are $30 at ecklers I think.
Old Oct 21, 2002 | 10:59 AM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Testor's silver paint. Honestly, it's inexpensive, and doesn't look Bubba. I like the brushed aluminum look, anyway. :yesnod:
Old Oct 21, 2002 | 05:33 PM
sb69coupe's Avatar
sb69coupe
The vent ***** are held in between the dash pad and the vent duct itself. Replacing the passenger side one is easy enough since the lower dash pad is a breeze to remove. The drivers side one is a PITA since you've got to drop the steering column to get the dash pad out, then remove the duct, etc.
Old Oct 21, 2002 | 06:10 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: Chrome Ball Vents (sb69coupe)
Down and dirty "old indian trick"..... Just grab the ball and pull it out the front. Don't take the dash panels...drivers or passengers side...out. Pop the new ***** in the same way.
DISCLAIMER.....if you need to replace felts, etc, you cannot do it via this approach. If you just want a new shiny ball in there, it works fine. Chuck
Old Oct 21, 2002 | 06:13 PM
DaddyO's Avatar
DaddyO
Default Re: Chrome Ball Vents (Chuck Gongloff)
HA HA! That's great Chuck. So easy!
Old Oct 21, 2002 | 06:30 PM
Binnie77's Avatar
Binnie77
Just a 'heads up'. If you plan to replace the *****, be sure and replace the felts as well. It is the felts that collect the dust and grit and it will 'scratch your new *****' if you don't replace them too.
Old Oct 21, 2002 | 08:09 PM
chucks's Avatar
chucks
C3 of Year Finalist (stock) 2019
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Oldtimer
I did mine just like Chuck said. :cool:
Old Oct 21, 2002 | 10:51 PM
SAMMAN's Avatar
SAMMAN
2016 C2 of Year Finalist
Default Re: Chrome Ball Vents (chucks)
Old Oct 22, 2002 | 03:41 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Chrome Ball Vents (Binnie77)
It is the felts that collect the dust and grit and it will 'scratch your new *****'.
Am I the only one flinching when I read this statement :lol: :lol: :lol:
Old Oct 22, 2002 | 06:02 AM
Titanium Rat's Avatar
Titanium Rat
Default Re: Chrome Ball Vents (Desertdawg)
well i just got done playing with my *****. They are in good shape, just jiggle a little when i hit a bump. I surely dont want new ***** because mine are fine, i desided i needed felt around them then i asked my girlfriend to adjust them and they just move right back to where they started. So she played with them for a while, and they seemed to be fine after that. :lol:
Old Oct 22, 2002 | 09:54 AM
J75's Avatar
J75
OUCH!!Did`t it hurt when you had the plateing done? :eek:
To Chrome Ball Vents
