1979 matching numbers
Old Oct 21, 2002 | 11:34 AM
KJB21's Avatar
KJB21
Default 1979 matching numbers
Hey Guys,
Where do I check for matching numbers on a 1979? Thanks for your help. :D
Old Oct 21, 2002 | 11:52 AM
Neo Fender's Avatar
Neo Fender
Default Re: 1979 matching numbers (KJB21)
The VIN is on the driver side a-pillar and it should also be stamped near the front of the passenger side cylinder head:
Serial Numbers: 1Z8789S400001 through 1Z8789S453807
Fifth Digit Code: 8=350ci 195, 4=350ci 225hp
Suffix:
ZAA: 350ci, 195hp MT EP
ZAH 350ci, 195hp AT
ZAB: 350ci, 195hp AT EP
ZAJ: 350ci, 195hp CE
ZAC: 350ci, 195hp AT CE EP
ZBA: 350ci, 225hp MT
ZAD: 350ci, 195hp AT HA
ZBB: 350ci, 225hp AT
ZAF: 350ci, 195hp MT
CE=California Emissions, EP=Early Production, MT=Manual Trans, AT=Automatic Trans, AC=Air Conditioning, AH=Aluminum Heads, HA=High Altitude
Base Engine: 350ci V8 195hp
Old Oct 21, 2002 | 12:11 PM
sb69coupe's Avatar
sb69coupe
Check out this post for details. The archives and search feature are your friend :D
http://forums.corvetteforum.com/zerothread?id=367584
Old Oct 21, 2002 | 06:02 PM
Paul L's Avatar
Paul L
Here...
And here.
[Modified by paul79, 5:03 PM 10/21/2002]
To 1979 matching numbers
