1982 crossfire
Old Jul 3, 2018 | 07:26 PM
G3 Johnny's Avatar
G3 Johnny
1st Gear
Default 1982 crossfire
Hi , Had this car in Florida, great drive ….shipped to Europe and drove hard and fast down to Spain . it started rough running and found fuel tank pump rubber pipe shot and the filter.
fuel pressure back to 10+ lbs and starts and drives good but on kickdown at gear change motor dies momentarily into 2nd gear, then picks up max revs and dies again into 3rd gear
drives perfectly otherwise . any ideas? fuel? …..filter? (new) ….electrical ? ANYBODY had similar symptoms ? Im living in Spain so cant pop down to local Vette shop !!
Also all parts must come from U.K. or U.S.A...…... urgent advise PLEASE .or Email john.eismark@gmail,com....or..Watsup +34689956848.....Skype....
Thanks to ALL Vette nuts out there, this is my 6th Vette in 40 yrs !!
Old Jul 4, 2018 | 06:44 PM
terry82's Avatar
terry82
how did you check your fuel pressure?If you only have 10 psi then you need to replace the fuel filter and fuel pump.
Old Jul 6, 2018 | 02:24 PM
vince vette 2's Avatar
vince vette 2
Does the engine just die like it's going to quit, or does it stumble and run rough. I had the latter issue on my 1980. The cause was one plug severely fouled.
To 1982 crossfire
