Rear Wheel Alignment (Shim Question):
Old Jul 12, 2018 | 10:38 AM
Silver 7T8's Avatar
Silver 7T8
Default Rear Wheel Alignment (Shim Question):
In the process of setting Rear wheel alignment.
Is there a general "rule-of-thumb" regarding the rear shims?
IE: If an 1/8" shim is moved from the inside-pack to the outside-pack-
Will this increase the Toe-In an 1/8" ?
Regarding the FRONT-End Shims,
I have always used the following rule-of-thumb- to rough-in a setting.
Camber 1/16" Shim = +/ - 1/3 of a Degree
Caster 1/16" Shim = +/ - 1/2 of a Degree
Any of You Guys that have done Rear Home-Alignments may have figured this out?
Thanks for Any Suggestions
Old Jul 12, 2018 | 11:30 AM
ignatz's Avatar
ignatz
From basic geometry, in degrees, it ought to be (57.3 X shim / length of the trailing arm)
Old Jul 12, 2018 | 11:39 AM
revitup's Avatar
revitup
How long's a trailing arm? Assuming about 18", a 1/8" shim swap will change toe-in about 3/32", if my geometry is right.
Old Jul 12, 2018 | 12:01 PM
73C34me's Avatar
73C34me
I just did this last week. An 1/8” shin moved the toe in 0.156”, an additional 0.030” shim moved the tie in .037”. as read by the alignment shop.
Old Jul 12, 2018 | 01:14 PM
Silver 7T8's Avatar
Silver 7T8
Thank You KIND Gentlemen of CF ��
Just st the info I needed to "Rough-In" the alignment.
Old Jul 12, 2018 | 09:12 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Another Rough-in check/measurement: place a straightedge against the inside of the frame on the passenger's side and measure the distance between the straightedge and the inboard side of the trailing arm near the rear edge. Write down the measurement.
Then use the same technique on the driver's side. The two measurements should be reasonably similar
Old Jul 12, 2018 | 10:03 PM
george2066's Avatar
george2066
what is the process for this, alignment shop first starts by making it 0 degrees toe, the adjusts to 1/8 toe in(which kicks the back of the tire out?)
Old Jul 14, 2018 | 10:25 AM
cagotzmann's Avatar
cagotzmann
Because of how shims are installed (assembly required) they should first set the thrust angle, then adjust the toe. Once the thrust angle is set you can adjust (shim) equal on both sides to maintain the thrust angle of the rear. This assumes the camber has been already been set.
Old Jul 14, 2018 | 01:04 PM
ignatz's Avatar
ignatz
I should have thought about my geometry calculation a bit more, similar triangles would suggest that the shims have proportionality to the trailing arm length divided by the tire radius.
With regard to "thrust angle" I have always set my rear toe-in in relation to the front wheels, as measured from the tire, using the string method, However my fronts and backs are always the same size, so if that is different, your statement about thrust angle is more accurate.
Also, as I half way remember, isn't the rear track slightly wider than the front track?
Old Jul 14, 2018 | 02:04 PM
cagotzmann's Avatar
cagotzmann
Yes the rear track width is wider, but how you setup rear thrust doesn't matter as long as each side is the same.
eg when I measure rear thrust from the picture. I have a laser mounted to the rear wheel. It might be toe out or toe in, I don't care. I make sure left and right is the same reading. Then I setup to get the correct toe by moving equal shims width on both sides.
So I don't know how you would use strings to measure thrust, other than the string is parallel to the rear wheel and measure the distance of the string from the front hub ? Its very difficult to setup a string parallel when you only measure the distance of the wheel width and then measure 98" away from that point. eg if the string parallel is out by 1/64" (15" wheel) over a distance of 98" (wheel base) = 5/64 variance. That is poor accuracy. You need a fixed mounting on the rear wheel that extends past the front hub.
Old Jul 14, 2018 | 08:39 PM
ignatz's Avatar
ignatz
Thanks. Didn't mean to imply that I measured thrust using the strings and have to admit I've never tried to measure thrust angle. Maybe someday! The thrust angle, as I understand it, is a perpendicular to a line through both rear axle centers and should align with the centerline of the car. I work till I get equal toe on both sides of the car.
Here's a link that suggests that that is all that's needed
http://lshapedgarage.blogspot.com/20...asurement.html
Is this wrong somehow?
Old Jul 14, 2018 | 08:45 PM
keithl1967's Avatar
keithl1967
Not to high jack the thread, but I am replacing my trailing arms as well... when I take it to the shop for the alignment, should I expect them to set a '77 to stock alignment, or should there be an 'adjustment" for the fact that I am running wider/taller tires (25560/15)?
Old Jul 15, 2018 | 12:47 AM
cagotzmann's Avatar
cagotzmann
I like the idea, but I would like to simulate in 3D with different track widths and different tires front & rear to see how the measurements are effected. But if everything is the same I don't see why this wouldn't be a good method using strings.
To Rear Wheel Alignment (Shim Question):
