79 tapping noise... fuel pump...
Old Oct 21, 2002 | 11:27 PM
dkgrn79's Avatar
dkgrn79
Default 79 tapping noise... fuel pump...
Why the heck is this tapping noise coming from my fuel pump which pings back all the way thru the fuel lines? I can hear it the loudest near the right (passenger side) wheel where the fuel lines run next to the frame. I have a replacement pump, which i am positive i installed correctly. I measured the push rod, and it is almost exactly 5.75 inches. Can any one think of a reason why this tapping noise continues after replacing the pump? I broght it to a local mechanic who said the noise is definitely coming from the fuel pump...
Please help!
Old Oct 21, 2002 | 11:33 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Default Re: 79 tapping noise... fuel pump... (dkgrn79)
Are you sure the pushrod is seated properly? Did you place grease or assembly lube on the end to hold it in place, as you installed the pump?
That's all I got... :(
Old Oct 22, 2002 | 07:28 AM
Gary79's Avatar
Gary79
Default Re: 79 tapping noise... fuel pump... (joeveto)
are sure its the pump? try tightening your exhaust manifold bolts.
Old Oct 22, 2002 | 10:21 AM
R. Bruno's Avatar
R. Bruno
Default Re: 79 tapping noise... fuel pump... (Gary79)
I read of a similar problem in Corvette Fever or Vette in the letters to the editor or whatever they call it section but can't find the issue. (was the last couple of years issues I think). Anyway, the advice of the author was that this is possible and is a sign of a bad pump.
Old Oct 22, 2002 | 10:56 AM
dkgrn79's Avatar
dkgrn79
Yah, I am pretty sure that the rod was seated properly. I used a big dab of grease to keep it from falling. I'll check the manifold bolts tonight. If that doesn't do it, i'll try (another) new pump.
Thanks for your suggestions. I'll post my results when i figure this out!
Old Oct 23, 2002 | 02:09 PM
dkgrn79's Avatar
dkgrn79
Okay, is the rocker arm on the pump supposed to move around? It seems really loose. If i push real hard, i can compress the arm and make the pump go, but i can grab the rocker arm with two fingers and wiggle it all around, up, down and back and forth... is this normal for a new/rebuilt pump?
Anyone know?
I hate tapping noises..
Old Oct 23, 2002 | 05:24 PM
lou's Avatar
lou
While you have it out, I think you should put in a new fuel pump rod. It's only a couple of buck at any auto parts store. That's what I had to do to get mine to stop tapping after I change the fuel pump. lou
Old Oct 23, 2002 | 05:34 PM
Fevre's Avatar
Fevre
If you feel like getting real crazy, put the base plate on with some tape over the pump hole and start the car without the pump installed. Car won't run very long but will tell if the noise goes away. Worse case is the pump lobe on the cam is gone, hope not. :(
Old Oct 23, 2002 | 06:59 PM
toyvet1's Avatar
toyvet1
Default Re: 79 tapping noise... fuel pump... (Fevre)
Heres a long shot. In 1979 Cheverlot saved a few cents in the hardening prosses on small block cams. The result was cam lobes rounded off.
I had to chenge out my cam ofter four years and twenty thousand miles. GM agreed the was way to low milage for a cam to round off three cam lobes.
GM paid for a new cam, lifters,gaskets and a few other small things admiting the had a batch of bad cams.
Maybe your fuel pump cam is worn and has too much slack causing the rattling.
My car has a serail number of 29xxx so it's about mid production. I hear the problem was 78 to mid 79.
Like I said a long shot but worth looking into...
Old Oct 24, 2002 | 07:56 AM
Gary79's Avatar
Gary79
Default Re: 79 tapping noise... fuel pump... (toyvet1)
i had a bad cam in a 305 V-8 in my 78 chevy van, 23,000 miles, went to the dealer, nothing wrong, kept going thru fuel pumps, til i put an electric pump on it. Didn't find out about the "soft" cam problem until fall of 1985 when i was at a different chevy dealer buying a Celebrity, by that time my van was out of warranty and i had lost all paper work on oil changes and maintenance, so i was out. GM also changed alloy composition on their front springs on some 1979 cars and most of their 1980 GM car line. i had a Pontiac Sunbird with soft springs and my Mom had a 1980 Olsmobile Delta 88.
Old Oct 24, 2002 | 10:51 AM
dkgrn79's Avatar
dkgrn79
Well... maybe thats it then. Time for an electric pump. I did tighten my exhaust manifold bolts, thanks for that advice gary79, however; the tapping noise persists....
DOH!
Old Oct 28, 2002 | 04:21 PM
dkgrn79's Avatar
dkgrn79
Replaced the push rod this weekend. That Didn't help at all. I'm thinking about getting a longer rubber hose that runs from the pump to the metal fuel line to see if i can deaden the noise a bit.... any one have any other ideas?
Old Oct 30, 2002 | 03:08 AM
lou's Avatar
lou
Only thing else I can think of is make sure your new pump is the correct part, if it is, I would return it and try another one. After that, the only thing left is the cam but I thinking if it was the cam it would have done it with the old fuel pump. So if it made that noise with the old pump, you might be looking at a bad lobe on the cam. lou
Old Nov 4, 2002 | 02:48 PM
dkgrn79's Avatar
dkgrn79
It did make the same tapping noise with the old pump. :sad:
To 79 tapping noise... fuel pump...
