1980 corvette
Old Jul 16, 2018 | 03:54 AM
rdv3842's Avatar
rdv3842
1st Gear
Default 1980 corvette
1980 corvette with 305 cid, is it lock up converter, cuz i wanna change my thm 350 thm700 r4
Old Jul 16, 2018 | 12:58 PM
MelWff's Avatar
MelWff
if it is the original transmission it has the lock up converter.
Old Jul 16, 2018 | 09:45 PM
av81's Avatar
av81
Lock up converters came out in 81
Old Jul 17, 2018 | 03:13 AM
v2racing's Avatar
v2racing
No, TH 350C trannies were in 1980 Vettes. I had one, seen lots of others.
Mike
Old Jul 17, 2018 | 07:30 AM
av81's Avatar
av81
I guess I stand corrected
Old Jul 17, 2018 | 08:52 PM
av81's Avatar
av81
I had to think about this cause I had a new L82 1980 and it did not have a lockup converter , here's the answer some do some dont.
The NCRS manual appendix I have lists (3) automatic trannys for 1980 (page 126):
MV4 = THM 350C
MX1 = Automatic Transmission
M33 = THM 350 (for California)
Old Jul 17, 2018 | 09:02 PM
v2racing's Avatar
v2racing
MV4 = THM 350C
I'm surprised the 350C wasn't used in California.
Mike
Old Jul 18, 2018 | 06:44 PM
terry82's Avatar
terry82
does it matter what you have?you are changing everything anyway.you will need a lockup for 700r4
Old Jul 19, 2018 | 08:14 AM
DVAST8R_88's Avatar
DVAST8R_88
So, if it had the lockup, but not the computer that the '81 has, what enabled it to lock?
Curious because I have an 81 that had the computer stuff disconnected by a previous owner.
Old Jul 19, 2018 | 09:05 AM
terry82's Avatar
terry82
if you had a lock up, it was not working .if all the computer parts were disconnected,then it was not getting any info.I have changed these over on 81s and they did not have the lock up.You can look to see if you have any wires going to the tranny..If you do find lock up wires ,you cant use them for the 700r4
Old Jul 19, 2018 | 12:20 PM
wajulia's Avatar
wajulia
Note the OP said it was a 305. 1980 California only 305CI with the ECM, Computer Controlled Carb and Turbo350 with the lockup converter -- all the same as the 1981 with a 350CI engine a year later. An obscure little corvette trivia question.
To 1980 corvette
