Engine Stopped While Adjusting Timing
Old Jul 21, 2018 | 10:42 PM
kbacklund's Avatar
kbacklund
Default Engine Stopped While Adjusting Timing
So, I was recurving the distributor on my 78 L48 today using the latest instructions from Mr. Lars. Everything was going smoothly and the engine was running fine (even took it for a small test drive). While making a small final timing tweak the engine just stopped. Turns over, but will not restart. Waited 20 minutes and nothing. Held pedal to floor (thinking it might be flooded) and nothing. Fuel is getting to the carb (I can see it when the accelerator is pumped). Has to be distributor, right? Can’t imagine what would have caused it to just shut down (and not want to restart).
Old Jul 21, 2018 | 11:07 PM
cagotzmann's Avatar
cagotzmann
I would check all wiring connected to the distributor. I would guess a connection providing a signal / power / ground has come disconnected. Check that any fuses didn't blow as well.
Old Jul 22, 2018 | 06:50 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
check the advance springs in case they fell off. you could mark the base where it is then back the distributer off a little to see if it will restart as well
Old Jul 22, 2018 | 07:31 AM
HeadsU.P.'s Avatar
HeadsU.P.
cagotzmann is correct and I think he is referring to the connectors at the dizzy cap. If you want to see what s going on inside, remove the coil dust cover (3 screws) then you can inspect all the connections. The front two "clips" are Tach on the left, Hot Wire on the right. Behind those are the modules clip..
Because you were turning the dizzy while setting the timing, I suspect a connector popped loose.
Old Jul 22, 2018 | 10:02 AM
kbacklund's Avatar
kbacklund
Checked fuses, power to dizzy, connections, springs, and eventually spark at #1 plug. All good. Tried to start it after and she fired right up. Could have fixed a connection in the process. Or maybe it was just flooded.
Old Jul 22, 2018 | 10:24 AM
HeadsU.P.'s Avatar
HeadsU.P.
Issue- code letters: kbknd-78 New parts / No Start Issue.
Resolved by owner, no assistance needed.
Charge of $119 waived.
How do you wish to NOT make your payment?
Old Jul 22, 2018 | 10:37 AM
kbacklund's Avatar
kbacklund
Good and bad, right? I am an engineer by training and I want to know what the problem was! 😂
Old Jul 22, 2018 | 11:07 AM
HeadsU.P.'s Avatar
HeadsU.P.
Like cagotzmann said, had to be the wire connections after you played with the innards. As you saw, there are sooooooo many wires to a HEI Ign system and some are hidden under the rotor. The module I believe has four by itself.
Next time you feel like playing with the dizzy, remove the coil dust cover. All four corners of the coil get a attachment bolt, only but one corner will have a black Grd wire under the bolt / screw cap. Its important that under that wire is bare metal for a proper Grd. The coil may have a epoxy paint on it and will need a light sanding or wire brush to assure a excellent contact.
To Engine Stopped While Adjusting Timing
