Turbo Hydramatic 400 problem.
Old Jul 23, 2018 | 10:45 AM
Dennis Murawski's Avatar
Dennis Murawski
Default Turbo Hydramatic 400 problem.
My 1969 350 Cubic Inch, 300 Horsepower automatic transmission seemed to be working well. Cowtown Cars and Coffee had a gathering at Texas Motor Speedway this Saturday. After the event owners were allowed to take a few laps around their steeply banked NASCAR track. I did that. On the way home I started hearing and feeling "clunks" from the transmission. Is it possible that the steep bank allowed the transmission fluid to flow away from the pick up and under strain damage the unit? Any suggestions for the rebuild? Thanks. Dennis
Old Jul 23, 2018 | 11:15 AM
bashcraft's Avatar
bashcraft
You would've known if it ran out of fluid. Anyway, if you were going fast enough, centrifugal force would've kept the oil in the pan where it's supposed to be.
Old Jul 23, 2018 | 02:50 PM
MelWff's Avatar
MelWff
when do the clunks occur, when you are standing still and shift from P into D or when the car is moving?
Old Jul 23, 2018 | 03:24 PM
Jeffs82c3's Avatar
Jeffs82c3
Worn out u-joints will clunk...
Old Jul 23, 2018 | 07:55 PM
Dennis Murawski
When the vehicle was moving and especially when it was in reverse.
Old Jul 23, 2018 | 11:51 PM
7T1vette's Avatar
7T1vette
Well, on those race tracks they don't allow you to go as fast as you need to put the oil where it should be. But, I would think you'd know that the trans was starving for oil at that time.
Could be a coincidence...or perhaps the track event put some 'new' stress on some old parts.
Old Jul 25, 2018 | 03:05 PM
Dennis Murawski
I had coffee with a friend this morning. He had a C3. He said what I was describing was exactly what he experienced when his Positraction went out. We'll check it out.
Old Jul 25, 2018 | 05:03 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Post what you discover/pics if you have them for future reference (as mentioned, you may want to check all the u-joints and diff. rubber snubber first just in case)
Old Jul 26, 2018 | 05:15 AM
terrys6t8roadster's Avatar
terrys6t8roadster
For the OP, try changing the dif fluid, make sure you add the posi supplement. T
Old Jul 26, 2018 | 02:41 PM
MelWff's Avatar
MelWff
How about the front rubber bushings on the differential mounting bracket to frame
To Turbo Hydramatic 400 problem.
