1974 Corvette Steering Column Too Short
Old Jul 26, 2018 | 08:29 PM
Quent's Avatar
Quent
6th Gear
Default 1974 Corvette Steering Column Too Short
Hey, I’m In A Bit Of A Dilema. I’m Trying To Reinstall My Steering Column On A 1974 Corvette. I Put It Back In But Its About 1.25 Inches Short Of The Steering Box. It’s Bolted In But Its Too Short, How So I Fix This Problem? Any suggestions ?
Old Jul 26, 2018 | 08:54 PM
Rodnok1's Avatar
Rodnok1
The shaft has collapsed most likely and needs to be pulled back out.
Old Jul 26, 2018 | 08:56 PM
Quent's Avatar
Quent
6th Gear
How Do I Pull It Back Out ?
Old Jul 26, 2018 | 09:23 PM
Rodnok1's Avatar
Rodnok1
Vise grips/small pipe wrench and wack on them, should move the shaft back down, if you have the rag joint still on column rap on it or use adjustable wrench up against it and rap on the wrench. They can be stubborn but since it probably went in easy maybe you'll get lucky and it'll slide easily back out.
Old Jul 26, 2018 | 09:29 PM
Quent's Avatar
Quent
6th Gear
Appreciate It. I Will Try It In The Morning
To 1974 Corvette Steering Column Too Short
