Replace cat with 'test pipe'
Old Jul 27, 2018 | 09:30 AM
Novusuhu's Avatar
Novusuhu
Default Replace cat with 'test pipe'
Hi everyone
I removed my mufflers yesterday, and wanted to hear the sound from the 'semi-straight pipes'.
I'm still running the original 2-1-2 system.
Everybody said, it was going to be 'LOUD', but when I started the engine, it wasn't loud at all. Just the same level as before.
I only could notice a slightly deeper tone. It was a bit of a disappointment ...
The cat (original) is still in place, so maybe the sound is still **** because of that?
I've been thinking of removing the cat, and putting a test pipe in place, but I can't find one with 4 bolt flanges on both ends.
I also can gut out the cat... or is it better to keep it original (How much is it worth?).
What are your thoughts and recommendations?
Old Jul 27, 2018 | 09:46 AM
BKarol's Avatar
BKarol
https://www.ebay.com/itm/CONVERTER-T...sid=m570.l1313
I would save it and decide later to rid yourself of it. Does your state require a cat? they will see if don't have one with the test pipe in place.
Old Jul 27, 2018 | 09:56 AM
bmotojoe's Avatar
bmotojoe
Unbolt your cat and bring it to a shop, they can build one for you. I was going to do the same but went 2.5" SS system and high flow cat. These flanges are 2.5" for reference.
Old Jul 27, 2018 | 10:02 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Your original stock cat is probably clogged. Simplest solution is to gut it so that it at least looks like it's there. I'm on my phone so can't see what state you're in but you need to take into account any local smog regs that you need to meet.
Having said the above, a modern, high flow cat is so efficient that you can have your cake and eat it too. You'll barely notice the difference in flow from a test pipe. Sound should be similar though I've never tested this.
Old Jul 27, 2018 | 10:33 AM
Novusuhu's Avatar
Novusuhu
Sorry, forgot to mention I'm from Belgium.
A cat is not required for oldtimers here.
Old Jul 27, 2018 | 11:13 AM
Novusuhu's Avatar
Novusuhu
I think I'm going to gut the cat as you recommended.
Are there side effects (in sound or safety) when doing this, Or does a 'gutted' cat simply works a straight pipe?
Old Jul 27, 2018 | 01:48 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
If laws permit, get headers and a true dual exhaust. This will give you the sound your looking for with the added bonus of more performance.
Old Jul 27, 2018 | 02:23 PM
sambrand's Avatar
sambrand
use a decent mask when u drill out the cat, the platinum beads also contain lots of unpleasant particles from lead to hydrocarbons. also it can be messy as all else so id would recommend doing so inside a large carboard box, that sooty mess from the old cats makes a hell of a mess on the garage floor.
Old Jul 28, 2018 | 11:00 AM
CA-Legal-Vette
It won’t be exactly the same as a straight pipe but probably close enough. Years ago, before it was a capital offense in CA, I bought a straight pipe that was made of steel, had the correct square flanges welded on to either end and even had a metal cat shell attached to the outside.
I know that the stock cat has a built in opening through which you can change the beads. I’ve never done this before and can’t imagine that it would come off easily, but I’d thank that’s the simplest and least messy route. All of the baffles and screens would still be in place though so I’m not positive this would get you the sound that you’re looking for.
Old Jul 28, 2018 | 11:26 AM
terry82's Avatar
terry82
I have had a open cat for many years .happy just the way it is .you wont gain anything with a test pipe.take a long rod and beat out the old crap inside .
Old Jul 28, 2018 | 01:14 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
If you can't or don't want to install headers. a couple of the American Corvette suppliers offer "true dual" exhaust systems that bolt up to the stock manifolds.
Old Jul 28, 2018 | 01:32 PM
AboveTheLogic's Avatar
AboveTheLogic
Side pipes!
Old Jul 28, 2018 | 01:43 PM
sambrand's Avatar
sambrand
years ago I cant remember where, I think jc whitney or jegs had a kit that welded into the pipe with a hood release type lever mounted in the cab that would open the pipes as much as u wanted to, this was supposed to give more power and allow you to "tune" the exhaust sound to your liking. I did a brief search and coulnt find it but im sure someone out there knows where/what this is.
To Replace cat with 'test pipe'
