I just bought a 1979 with a ZZ4 and am looking for recommendations on oil type viscosity and what type of filter to use on this engine. I have no documentation and the on line specs Ihave foungd are not very helpful.
Re: oil and filter recommendations for ZZ4 (adamdinat)
Welcome to the forum. Let me get your post back to the top. I use Valvoline 10/30 dino oil "Crisco" with a K&N filter. For your engine I'm sure you will get many suggestions. Are you planning trips to the track or Sunday driving? Will you store it for the winter?
A/C Delco PF35 is the filter of choice for me, actually the one I'm using on my ZZ4 is the higher grade of PF35, but I can't remember the number. I'm going to run Castrol 10w-30, for initial break-in, then switch to Castrol Syntec, synthetic.
I run 10w40 or 10w30 whatever I can get on sale. For a filter stick with AC Delco and try to get the longer filter. I think the long one is the PF35 and the short is the PF25. After I get some more miles on the car I will probably switch to Mobil 1.
Thanks for the help. What I am liking about the forum is the different approaches to problems. It really helps you make an informed decision. Here is what i recived form the customer service dept at GM.
The oil filter is either a ac-delco PF-25 or PF35. Gm recommends using a 10w30 regular engine oil for break in and suggests using a synthetic engine oil after break in due to the high performance nature of this engine.
Engine Block: Both engines use a cast iron 4-bolt main block, making them structurally similar.
Cylinder Heads: Both feature aluminum heads with 58cc chambers, though the ZZ4 has upgraded LT4 chrome silicon valve springs.
Camshaft: Both use a hydraulic roller tappet camshaft, but the ZZ4 has a refined version for better performance.
Pistons: The ZZ3 uses cast hypereutectic aluminum pistons, while the ZZ4 has high silicon aluminum pistons with offset pins—they are similar but not identical.
Ignition System: Both engines use an HEI distributor with centrifugal and vacuum advance.
Oil Filter: The ZZ4 typically uses an ACDelco PF35L oil filter, which is likely compatible with the ZZ3.
Fuel Requirements: Both engines require premium 92 octane fuel.
For a more detailed breakdown of service parts, you can check out this GM parts list. If you're looking for specific compatibility details for your Corvette, I can help with that too! Let me know what you need. 🚗💨
For a more detailed breakdown of service parts, you can check out this GM parts list. If you're looking for specific compatibility details for your Corvette, I can help with that too! Let me know what you need. 🚗💨 https://www.crateenginedepot.com/pdfs/SB_zzengine.pdf
