Are there any good instructions (illustrations) on how to replace the blower motor fan switch with heat and a/c on a 72 C3? Do I need to remove the entire console? jI tried to remove the faceplate and it comes up a little way but then acts like something is preventing it from coming up any further. It look like the a/c control module is holding things up.
You'll need to remove the shifter **** and T handle... then you remove the screws that hold the shift console plate in place....there should be four.
Once you remove the shifter plate you should be able to lift the plate off the console ( the heater control will stay in place)... There are two small screws that hold the heater control in place so once you remove these you should be able to pull it out a bit. There are two screws that hold the switch to the control and you can change it out without removing the cables.
thanks for your reply. My 72 only has the round shift **** with a spring loaded shift button. I unscrewed the **** and that was the trick. One thing I had to do to get the plate off was to shift it into neutral first. Other than that it was not too bad. Got the switch replaced. Thanks for everyone’s help
