So installed the 200r 4 trans and I can't get it to shift right .I did buy bowties tv cable set up for my edelbrock carb .My issue is it wont shift to 2nd till it hits almost 3000 rpm and it won't shift to 3rd till it hits 3500 rpm .I have tried setting the TV cable everyway I can .best I got it to change was from 1st to 2nd it would shift a tad over 2500 rpm but 3rd stays the same .
Transmission was ordered with a 2300 stall converter . I stress SUPPOSE to .I did not look to see if it was stamped with a marking .I does shift to all 4 gears but takes a lot of rpms to get it there .It also seems to downshift pretty hard too .
Wonderfull Facebook goobers say I have too high of a torque converter ,I have a 1978 with 3,08 rear end .
Will a lower rated torque converter lower my shift points as the facebook goobers say or are they blowing smoke to sound smart .
Thanks in advance for any help someone can give me before I pull all my hair out
The TV cable is extended too far at low throttle... OR... the TV valve is stuck near "WOT" position... OR... the valve in the governor shaft is stuck near WOT position.
You should take your car to a LOCAL transmission shop (not a national chain store) and see if they can help. You need some transmission knowledge and equipment to resolve this issue.
Note: When at idle, the TV cable should be extended very little or not at all. When at WOT (manually tested at carb), the TV cable should be extended nearly to the end of its travel range. Setting this adjustment properly is a 'geometry' problem with carb linkage. Your transmission shop can measure TV line pressure to determine what is going on as cable is moved.
there is just a tiny bit of slack in cable and is fully extended at wot .I can feel spring tension on cable it I disconnect and just pull on cable .I do have a tiny trans pan leak I will be removing pan to replace gasket .Is there anything I can look at when I do this .Is TV valve accessible when pan is off .I live out in the country and only trans shops even close by are chain store outfits that I cant stand ,Their first response when I called was "You need a NEW trans "
Also I can idle car up to about 1500 rpm and with the TV cable disconnected from carb I can pull the cable and at about full travel of cable I can see pressure on gauge I have on trans go from 150 psi at idle to 170 to 175 psi .
You mean it takes 1600+rpm for the car to start moving at all? Requiring 1600+ rpm just to make the car move is a messed-up converter. It may be a really high stall or it may just be a bad converter. A decent 2300rpm stall converter would start moving the car at idle. Heck, even most of the cheap 2300rpm stall converters would. If the converter slips that badly then it could be causing the issue if it's adding a lot of slip all the time pushing your engine rpm way higher than it needs to be.
As for the pressures. Does the pressure change from about 70psi to that 175psi as you pull the cable while testing at around 1500rpm? You could test in each gear at no and full TV cable pull and 1500rpm and post the results.
No thats holding foot on brake in gear ,If I just tap gas at idle ,no foot on brake it moves immediately,The pressure is always on 150 at idle ,when I pull cable it will go up 20psi to 25 psi
FYI update ,
I dropped pan and inspected governor and 1-2 accumulator nothing is stuck or sticking everything moves freely .So I do wonder what color spring is suppose to be in 1-2 accumulator.The one in it is colored red .Don't know if it is the oem one or not .
Also how can I tell if the governor and/or springs are the oem ones or the performance springs .
That sounds like a TV valve stuck. With engine off, unhook the tv cable from the carb linkage, pull it out all the way by hand and let it snap back in a few times, then hook it back up and recheck pressure. You should be at 70-90 at idle then start to rise instantly when the rpms are increased.
This shows the different weights for the gn governor and the standard gov. Monte ss had a performance gov also.
mine looks like the bottom one .I also finally got the company I bought trans from to answer my emails .I was told this trans has a shift kit in it .UGH .SO now I may just be stuck with it .I bought trans over a year ago and just installed it last week .If I change out governor with the GN one will this help the hard high rpm shifts or is it also a result of this trans shift kit .
I really believe the issue is with the tv valve being stuck. A shift kit shouldn't cause the issues you are having.
I have the pan off and can push plunger in and it comes back out freely .Or is this just the spring I am feeling and valve is still stuck?
Before I dropped pan i did disconnect it and pull cable and let it spring back 2 or 3 times but it did not change
I know that early 700-R4's had a problem with sticking TV valves. There is a special kit to replace them with the new design. You might do some research on that for 200-4R's. I also believe that the valve is sticking. I don't believe TV pressure should be anywhere near 150 psi at idle. Figure this one out while the pan is off.
Also, you might consider buying a valve body rebuild kit for a standard-build unit and ditch the "shift kit". It is also possible that whoever installed the shift kit screwed up the TV valve.
