79 Tach Issues
Old Aug 13, 2018 | 03:45 PM
mbb9674's Avatar
mbb9674
Default 79 Tach Issues
My 79 L-82 tach is acting funky under load. While in park I can rev the engine up to ~4K rpm and the tach tracks correctly and settles back down how I would expect it to act. But, while under load in first gear if I get on it once I get to 3-3200 rpm my need starts erratically flickering between 2-4K but when I let off, or the trans shifts, it starts acting normal again. Also when I shut the car of and have ignition in the off position the tach will jump to 1000 rpm but in the on position it goes to zero. I replaced the original tach board 3 years ago when the tach just quit working all together but replaced it with another spare 79 board I had around. Think the board is giving me issues or is there something else? I also just replaced my hei coil and module with DUI pieces and can’t remember if I had the issue before since the car had been down for the last year.
Old Aug 14, 2018 | 11:44 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
It sounds like the board is the issue.... by design the tach board should remember the last signal sent to it and in the old days when we'd buy used tachometers we'd look for them with a 700-1000 rpm reading. To us (when we didn't make the boards), that would indicate the board was working when the tach was removed.
But you issue sure sounds like the chip is failing on the board.
There is a ton of tach info on our tech site at this link. http://repairs.willcoxcorvette.com/?yt=1979&s=tach
And we actually make the boards in the USA at this link https://willcoxcorvette.com/corvette...78-79-usa-made
Willcox
Old Aug 14, 2018 | 06:09 PM
mbb9674's Avatar
mbb9674
Thanks Willcox,
I’ll get one of your new ones ordered here in the next few weeks. Thanks for the response, I was hoping you might chime in after seeing all of your other posts regarding the tach boards.
Old Aug 14, 2018 | 10:49 PM
0Willcox Corvette
Former Vendor
Thanks Willcox,
My pleasure.. if you want you can send in the tach and we will match calibrate it to the analog movement.
it's not cheap but it's as accurate as can be had.. we match the board to your movement.
https://willcoxcorvette.com/corvette...-service-75-82
Willcox
Old Aug 15, 2018 | 08:19 AM
mobird's Avatar
mobird
If it doesn't end up being the board, I have an oddball solution. My tach did this same thing recently, and it ended up being a partially burned up fusible link. Somehow the car still ran and acted normally, but the loose connection at the fusible link was making the tach bounce erratically.
Old Aug 17, 2018 | 11:27 AM
mbb9674's Avatar
mbb9674
Thanks mobird I’ll have to look into that as well for something obvious before I pull the tach out.
Willcox,
Do you notice much variation in readings between the calibrated vs not calibrated board to movements and the actual rpm or are they fairly close say 5% or so?
Old Aug 19, 2018 | 08:17 PM
0Willcox Corvette
Former Vendor
Willcox,
There isn't much variance in board calibration, but what we are finding more and more is analog movement failure. We have established what we deem as an acceptable range within what we also deem a close margin for error. This range has been established over 20 years ago in testing original movements over and over and over again.... So we don't have much of an issue when selling the boards. In one of my original videos I did on installing the boards it's evident that the OEM original board was less accurate than the one we placed on the tach..... The OEM original GM tach's were close but they were no work of art that's for sure.
It's always best to be able to have the original tach and board in hand and be able to dial them into match each other.. The issue is that for a customer to do this is next to impossible without a signal generator. The tach's are calibrated at 4000 RPM's... so for someone at home to do this they'd need a way to read the signal and also hold their tach to 4K, once you dial in 4K, the rest will fall in place. The changes at 4k are huge, but at the lower end of the scale they are very small. So tweaking one at 700 could make your tach way off at say... 3k rpms.
In the old days, maybe 1 analog movement a year would be bad..... but in the last few years we've seen an drastic increase in analog movement failures.
We just had a customer send his tach in and the movement is failing... There is a short inside the movement and the cost to repair is more than the cost to just purchase a new tach.. On this particular movement, we can put a board on it... wiggle one of the studs and the board works... then it tanks.. wiggle the stud again and it works for a minute, then tanks again....
The cost to the customer to take the movement apart and attempt to fix is no where near the cost to just purchase a new (as bad as I hate to say it) imported tach. The funny thing is that we changed our tach board to work as a replacement for both the original boards as well as the imported tach boards. Original boards shared a common ground, the new imported boards have a separate ground (dual).... We're just preparing our selves for when the new imported tach boards start failing, we'll be ready.
Willcox
To 79 Tach Issues
