Dewitts HP Radiator Fit
Old Aug 17, 2018 | 03:24 PM
Busrydr's Avatar
Busrydr
Default Dewitts HP Radiator Fit
Greeting all and happy Friday to all. Need to see if I can get a question answered.
I'm upgrading my 1973 350 automatic from stock radiator to Dewitts HP. The original L-48 was replaced with a GM HO 350 crate long block.
Car was also originally non A/C, but that was remedied with a Vintage Air install. Using the OEM 7 blade fan spec'd for a 73 with factory A/C.
Question is: will the HP version of the Dewitts radiator fit my stock radiator supports without modifications? I do plan to inspect the support once the radiator is out. But if all looks good, I want to know if this would still be a drop in plug and play or if the HP makes things different as far as fit.
Thanks for your input.
Old Aug 17, 2018 | 03:35 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
I’m pretty sure the radiator is either 26” (no ac) or 27” (ac). The radiator support will determine which radiator to use.
Old Aug 17, 2018 | 03:47 PM
Busrydr's Avatar
Busrydr
Thanks Bob. That's what I'm trying to confirm for thec1973 year. It looks like there is only one model for the 1973 support. Websites list All when they reference that year. Some other years show differences for with A/C and without.
I have a call into Dewitts directly, but no reply just yet.
Old Aug 17, 2018 | 03:57 PM
71 Green 454's Avatar
71 Green 454
FYI... Order a new DeWitts Radiator from Zip now through August 20th at midnight and receive FREE SHIPPING* on your order! Free Shipping is applied automatically at checkout.
Old Aug 17, 2018 | 04:07 PM
Busrydr's Avatar
Busrydr
Yes Sir! I saw that at Zip and at the premium price for a quality piece, every little bit helps.
But I need to factor in the support cost should it be required to modify or replace if fitment is an issue.
Old Aug 17, 2018 | 05:12 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
As mentioned, there was only one core support for 73-75, and that's for a 27.5" core. If you go with the DeWitt model it will have the factory type GM hat channels. There is also a custom channel matching cushion for the perfectionist.
CUSTOM CUSHION
Old Aug 17, 2018 | 05:25 PM
Busrydr's Avatar
Busrydr
Thanks Tom,
So that I'm crystal clear. The standard and the HP radiators from Dewitts for the 1973 Corvette 350 automatic will both fit the stock radiator support without modifications. And fit better with the custom cushions offered :-)
Thanks for chiming in.
Old Aug 17, 2018 | 08:01 PM
Busrydr's Avatar
Busrydr
Okay Tom,
Based on your input I was able to look of the core size and both radiators appear to fit the 1973 27.5
Old Aug 17, 2018 | 08:12 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Thanks Tom,
Yep, the Pro-series and HP are dimensionally identical. Just the core thickness changes
To Dewitts HP Radiator Fit
