just bought 69 corvette sitting a few years
want to top off brake fluid dot 3 or dot 5?
how can i tell its been 10 years since calipers have been replaced
Dot 5 is blue, but might be hard to tell color on 10 year old fluid. Usually the smell gives away Dot 3. Sniff it and compare to fresh Dot 3.
So the brake fluis emosified i changed 1 leaky caliper.
all four were replaced from Vette brakes but one started to seep.
so changed out all good.
Also found P/S leak culprit return hose on steering, so i replaced that too.
