Rebuilding my L48 Engine - Advice Needed
Personally, I have a motor roughly in your power range and I always want a little more power. But I also like to drive my car like I stole it haha. If you really don't care about power and just want something to cruise around in, then the 350 is just fine! It just seems a shame to have the block apart and buy a new rotating assembly and give up nearly free cubic inches!
That way when you want a little more power.
You don't have to worry about durability!
JMHO
R
Based on the posts and additional research, I think I'll leave it at a 355. No need to stroke it.
4.03" bore
3.48 stroke
64cc head (Either the ProMaxx or Edelbrock - still deciding)
Keith Black KB193-030 pistons (dished 12cc volume)
Gasket: .041" (also could go with a .015" option)
I'm getting 9.2 - 9.6 static compression ratio and with my cam it drops to 7.7 - 8 dynamic compression. The variation is based on deck clearance and gasket thickness. The pistons are rated at 9.6 CR for 64cc head which appears to be calculated at 0 deck clearance. If I went with the thinner gasket it could be as high 10.2CR (8.5 DCR) if the deck clearance is 0. I wouldn't want to go that high.
From what I've read, 8:1 DCR is a good target to shoot for. Much higher and you run the risk of detonation.
i run the keith black d-dish pistons as well, a good choice imo. 1.561 CH and nice squish pad.
make sure to follow their guidelines regarding the gap on the top piston ring.
if you are zero decking the block then a .041 gasket is a good choice, however if the deck is still stock with piston .025 in the hole then you need the .015 shim to achieve .040 squish.
I love having HP, but I don't want to get into a position where the HP starts tearing up other components like my rear end, which I understand the 80 aluminum diff isn't the strongest.
If you need a new rotating assembly than definitely go 383.
If not stay with the 355 using the OEM rotating assembly especially at the power level you are shooting for. I reconditioned my forged OEM L-82 crankshaft, reconditioned the OEM L-82 rods, etc during my build of the OEM L82 in 2014. Based on what I personally knew about the 355/383 decision, my expert builder's advice and long commentary sessions with him, and what I read from many of the other SBC forums including F body camaro/firebird/chevelle/nova etc, I stayed with the 355 and extremely pleased I did. I was and still shocked at the power my L-82 355 makes on the street. If I wanted more power, which I do not, I would NOT be going 383 unless I had to replace the crank. I would look to 400+ CI SBC for more power, not a 383, since the cube difference is very small.
The split consensus is/was on other forums either the 383 will change your life versus the 355 OR the difference on the street between a healthy 355 and a strong 383 is VERY little. Some would say barely noticeable who have built BOTH (key word here...experience with both in the same car) to a very slight advantage for the 383 (.10 sec 60 foot time...direct quote) versus their healthy/strong 355.
Bottom line, need a new rotating assembly, 383 all day long! Want 475+ Gross HP 383 all day long since it is easier to hit that power level with a few more cubes....Other than that build a strong 355 with a shorter duration cam (mine is 219/225 which gives strong bottom end and BIG mid range torque), great heads along with moderate compression and you will have a great combo for the street.
This is a stronger argument if starting from a forged L82; he's got a cast L48 crank; a modern cast SCAT 383 crank is still going to be significantly stronger than the cast L48 crank, so might as well get the extra 33 cubes along with the stronger crank.
Plus like you said, everyone THINKS that the 383 makes a huge difference and desirability and selling price go hand-in-hand. (Will you get back the extra $200 for a cast Scat 383 crank? Surely.)
Adam
Better question is how different is 450 Gross HP whether from a 355 or a 383? About 300 RPM difference across the area under the curve for HP and Torque.............They are both going to be fast, regardless.....
There is no getting around or away from that the difference is 33 cubes between a 383 and 355!!! It's not 80 cubes, 100 cubes or 125 cubes...it is 33 cubes. Don't expect miracles folks!....In other words, it is 5.8 Liters versus 6.3 liters...Holy smokes .5 (1/2) liter bigger for the 383 versus the 355...Give me a break............
I have said this before and will again, unless the 383 build is optimized for the extra cubes, a strong 355 could and would actually be faster....The 383 has more potential but that is where the advantage ends unless taken advantage of.........relative to a strong 355
Adam
He is looking for 300-350 Gross HP motor...He does need a Forged 350 crank and certainly not a 383 crank for that type of power target......His cast crank is good for 400 Gross HP....
Changes in SCR and DCR are equal with a head gasket change. As an example:
SCR is 10.36 with .041 gasket
SCR is 10.80 with a .025 gasket
That .44 difference in SCR is also a .44 change in DCR. Others can correct me but a gasket change will only go so far in regards to an SCR/DCR change but its mostly an SCR thing as it can either get you into or out of a ping/detonation condition, Any unwanted change in DCR from a gasket change can be made up for with a change in camshaft IVC.
I crunched your numbers for a 355 and it comes up with 9.64 CR with a DCR of 8.09. That's pretty good. With aluminum heads you could push that up to 8.5 DCR and still be good.
I figured 11.7cc's for those 12cc dish pistons, that's what mine cc'd out to.
Make it a 383 with that cam and your up to 10.31 CR with a 8.69 DCR. Bit high on the DCR. But you would also get different pistons so hard to say what it might be without knowing that.
If you're considering going below .035-.038 on the quench, don't do it. .040 is plenty and getting closer is of no advantage when weighed against the risk of striking the head with the piston.
Smokey Yunick found that a tight squish was benneficial back in the 1960's!
Mike
He needs to decide: no crank or new crank and with a good set of heads and that cam it's going to be hard to keep the motor down at 350 -375 crank HP. Better safe than sorry, and if he's buying a new crank anyway, he should get the extra 33 cubes for "free". (This is why I said the calculation looks different for people who are starting from an L82 forged everything vs an L48 crank with a 350-375hp safe limit.)
-Sometimes the decision YOU made, might not be the right decision for someone else.
Adam
Mike
Mike
Adam
Adam
Good points here for sure! I think you hit the real decision on the head: 1. Go the cheaper route (machine the stock crank, replace the pistons and rings, get some aftermarket heads) and have close to 400hp, but be basically at your power limit. Or 2. get a 383 kit (may not be that much more expensive once you calculate it because machining your stock crank isn't free! You can get a decent stroker kit for about $1,000, and that will include pistons, rings, crank, bearings, flywheel/flex plate, etc...) and have the extra cubic inches (more power, and future power potential), stronger crank, more low end torque, etc...
If you are SURE you won't be wanting for more power with a 350-400 hp motor (keep in mind that is flywheel horsepower, you would be putting something like 275 horsepower to the tire) than I would go straight for a budget rebuild on your crank, new pistons, and some good heads (DEFINITELY look at the Jegs brand heads, they are Profilers and cost $999 a set).
If you think there is a possibility that the above will eventually not be the horsepower you want, NOW is the time to go ahead and do a stroker crank while the block is apart. Right now, it's only a little more money to for a 383. If you build the 350 and decide you want a 383 later, it will cost alot more because you are buying new pistons, rods, and crank to replace the ones you already bought, plus the cost of gaskets and fluids AGAIN.
Personally, it's an easy choice to me: go 383 and don't look back. But only you can decide what is right for you and your car and your wallet.
A Cold Air Intake would be the best way to deal with being just over the edge of detonation with premium fuel in hot weather, IMHO. Every 8 degrees in IAT temp drop is a 1 octane equivalent increase in detonation resistance.
Adam
