Frustrated!
Old Aug 31, 2018 | 04:24 PM
Joel618's Avatar
Joel618
Cruising
Default Frustrated!
I have a 1976 Corvette, the headlights won’t work, I changed all vacuum hoses and even rebuild the actuators, I’m stuck and I don’t know where else to look, anyone have any ideas? Please!😞
Old Aug 31, 2018 | 04:27 PM
Peterbuilt's Avatar
Peterbuilt
Start at the manifold and follow the diagram and make sure that you connected everything correctly.
http://www.corvette-101.com/vacuum.htm
Old Aug 31, 2018 | 04:33 PM
mobird's Avatar
mobird
Do you have a hand vacuum pump? If not, rent one from your local auto parts store for free. Then you can hook it up to the headlight actuators and pump them by hand and you should see them slowly rise. That way you can at least verify that they are working properly, which would narrow your leak down.
You can also use that hand pump to verify each vacuum hose and relay to make sure they aren't leaking.
Old Aug 31, 2018 | 06:33 PM
DUB's Avatar
DUB
PM sent.
DUB
Old Aug 31, 2018 | 07:15 PM
Joel618's Avatar
Joel618
Cruising
Thanks guys I really appreciate it, i’m new one Corvette forum, and I find it very helpful ��... i’ll keep you guys posted.
Old Sep 1, 2018 | 09:47 AM
gjohnson's Avatar
gjohnson
My problem was the headlight switch
Old Sep 1, 2018 | 12:58 PM
Joel618's Avatar
Joel618
Cruising
I changed all the vacuum hoses and rebuilt the actuators, which I thought that was the problem because they were pretty bad, but no, the car was parked in a barn for acouple years, when I took started taking the interior out I found several rat nest in the car, One particularly inside the dash on top of the light switch, so my next step was to buy a new switch.
Old Sep 1, 2018 | 05:18 PM
DUB's Avatar
DUB
That may not be your problem. Just saying....there is way to verify if it is good or not. Also assuming that you replaced the vacuum hoses that go to your headlight switch or at least test them to make sure some rat did not eat a hole in one of them.
DUB
Old Sep 1, 2018 | 06:28 PM
Gale Banks 80''s Avatar
Gale Banks 80'
Sounds like You are starting to guess and replace parts. Almost always the problem is a Vacuum leak. You can hear a Vacuum leak if you eliminate the noise of the Engine. To do this run a long hose out of your garage to another car and or to a Vacuum pump. A sucking sound will lead you to the problem and or problems. No leak ? Ok now start at the engine and disconnect the first hose and stick a Vacuum gauge in it. There is probably 12-15 ins of Vacuum. Now go to the next hose and do the same thing, and on down the line till You find something that is blocking the flow.
Old Sep 4, 2018 | 11:22 PM
Joel618's Avatar
Joel618
Cruising
thank you, ill try that
To Frustrated!
