Looking for good input. I get a vibration, primarily through the steering wheel at about 48-60 MPH. It seems more intense when I press the accelerator and practically fades away when I let off and coast. All 4 tires are new. Balanced when installed and I recently had them re-balanced by my own mechanic. He said he thinks 3 of the wheels are out of "true" as they appeared slightly wobbly on the spin balance. He suggested taking the wheels off and sending them out to a company that straightens rims on cars, including high end cars. Apparently, they put the rims on a press. These are original rims, 39 years old. The car has 45K miles. While worth a shot, what are the odds this car has 3 bent (out of true) rims?
I've been thinking motor mounts or other front end components. It has a new power steering booster, new water pump, all accessory pulleys were re-aligned a few thousand miles back.
I hate the guessing game but the fun of driving it is slipping away.
I've been chasing a similar vibration.
New trans, all new ujoints and new rear wheel bearings. New tires coming next spring. Will check for wheel runout then.
I think (and hope) it's not a diff issue. It's full of new lube and modifier. I really don't want to tear into it again.
if its suspension related the vibrations will not fade when not under throttle, the issue is either a motor or trans mount, a sway bar link, or the wheel alignment possibly a wheel bearing but that is unlikely because if it were a bearing problem would be worse at lower rpm. so im leaning towards alignment.
drop it in neutral while the vibration occurs.. Does the vibration go away? If it does its more than likely a drivetrain issue.
Swap wheels front to back. Does it go away? If not swap them back where they were then swap left to right.
Its a process of elimination.
i'll try the neutral drop, easy. My letting off the gas and coasting makes it all but disappear. Same effect as neural drop?
I've moved the tires rear to front but not left to right. Before doing that i'll need to check to see if tires have counter-spin precautions on the side walls.
Thanks.
i vibrations will not fade when not under throttle, the issue is either a motor or trans mount, a sway bar link, or the wheel alignment possibly a wheel bearing but that is unlikely because if it were a bearing problem would be worse at lower rpm. so im leaning towards alignment.
I'VE DEFINITELY THOUGHT MOTOR MOUNT SINCE IT FADES WHEN I LET OFF THE ACCELERATOR. NO TELLING WHEN IT WAS LAST ALIGNED; BUT WHEN I REPLACED ALL 4 TIRES (2 were actually original) LAST YEAR I DIDN'T NOTE ANY UNUSUAL TREAD WEAR ON THE FRONT RUBBER, JUST DRY ROT FROM AGE. THANKS.
"Orginal to when you bought the car? Or original to the car at date of manufacture?
First thing is get good tires. Old tires may be bias ply with a flat spot, but then it would shake at all speeds. look for motor mounts. Maybe crumbled and fell out. In my opinion if its a motor mount the fan would more than likely be hitting the shroud. Any sign that the fan is hitting the shroud?
Had similar problem. It was the adjustable knuckle that the power steering ram was hooked to the tierod with. Accelleration unloadedi it and caused a wobble. Lettingboff caused it to settle back into the cup.
2 were original from the manufacture (thus the dry rot), I put 4 BF Goodrich Radial T/As on it a year ago and they have less than 1K miles on them. I'm thinking motor mount(s), too. No fan / shroud encroachment, however. THANKS.
had similar problem. It was the adjustable knuckle that the power steering ram was hooked to the tierod with. Accelleration unloadedi it and caused a wobble. Lettingboff caused it to settle back into the cup.
that makes some serious sense! Will bring that up to my guy, next week. Thanks!
Had a '72 Impala that would vibrate the front end at speed. You could feel it in the steering wheel. Thought it was shocks but ended up being a front coil spring had a broken a coil near the bottom end. I put a twist-in aluminum spacer block in there between the remaining coils and the vibration went away.
It was just a junky winter car for me - no judgement.
When I first got my '79 I had a rough vibration through almost this exact same speed range - replacing the 14 year old tires (and more likely the balance on the new ones) fixed it. Wheels could be it
Thanks.
A neutral drop disconnects the engine/trans from the rest of the drivetrain. Lifting up on the throttle does not. It's just a way to eliminate variable. Counter spin on tires doesn't matter as long as your not driving in the rain.
when i first got my '79 i had a rough vibration through almost this exact same speed range - replacing the 14 year old tires (and more likely the balance on the new ones) fixed it. Wheels could be it
