Fluid type ???
Old Oct 24, 2002 | 01:57 PM
myyellowc3's Avatar
myyellowc3
Default Fluid type ???
I need to know for sure what is the best type of fluid to put in our C3 Power steering system. When I originaly drained mine, it looked to be Tranny fluid. I had a guy at the part store say that Power steering fluid would work better. Any thought or personal experiances? :confused:
Rich :p:
Old Oct 24, 2002 | 02:11 PM
LABulldog's Avatar
LABulldog
Default Re: Fluid type ??? (myyellowc3)
Jim Shea of this forum recommended to me to use the GM power steering fluid. He told me that it was specifically made for the Saginaw (sp?) pumps that came on the C3. Its still available because I bought a couple of quarts a couple of weeks ago. Hope this helps. :yesnod:
PS How did you drain your fluid?
[Modified by LABulldog, 12:12 PM 10/24/2002]
Old Oct 24, 2002 | 02:39 PM
myyellowc3's Avatar
myyellowc3
Default Re: Fluid type ??? (LABulldog)
LABulldog,
Thanks for the information. I drained my fluid when I removed my control valve to rebuild it. (Disconnected the hoses) The rebuild failed, and it leaks like a cheap trailer. I have a rebuilt control valve on order from Zip. :smash: :smash: :smash:
Rich
Old Oct 24, 2002 | 02:50 PM
1978Vette's Avatar
1978Vette
dont worry thats just your car sweating from all the HP...... Yes use the fluid mentioned above :yesnod:
Old Oct 24, 2002 | 03:02 PM
DaddyO's Avatar
DaddyO
Yes, how do you drain it?
Old Oct 25, 2002 | 06:02 PM
myyellowc3's Avatar
myyellowc3
Default Re: Fluid type ??? (DaddyO)
I guess I forgot to mention that all of the fluid seems to come out when you take the hoses off. Drip, Drip, Drip. :smash: :crazy: :smash: :crazy: :lol:
Old Oct 25, 2002 | 06:22 PM
gmcclurg's Avatar
gmcclurg
Make sure you flush a quart or two through the pump and lines to get all the crud out. You don't want the grit to attack you new seals.
Old Oct 25, 2002 | 06:41 PM
Jim Shea's Avatar
Jim Shea
32 oz of GM power steering fluid is part number 1050017 and is available from any GM dealer. "An amber colored , light bodied mineral oil that contains a specially developed additive package to provide good performance in power steering systems. It also helps in reducing power steering noise. Especially formulated to provide anti-corrosive and non-foaming qualities with excellent lubrication for year round use." :cheers:
To Fluid type ???
