Engine knock created after shutdown backfire
Old Sep 6, 2018 | 08:22 AM
dyerk's Avatar
dyerk
Default Engine knock created after shutdown backfire
the other day I took a quick ride and when I parked the car and shut it down the engine ran on for what seemed long and did a hard pop out the exhaust. I feel like it reversed rotation. This is not normal for this to happen. The carb was rebuilt by Lars and timing set per his paper. I have a Mallory unilite without vac adv. and prior to this engine was running great. Now the engine sounds like drums in a tin can or loud knocking at all rpms. Someone told me timing could have jumped. Is this a condition that could happen. Any other ideas what to check? Thanks in advance for your help.
Old Sep 6, 2018 | 09:00 AM
HeadsU.P.'s Avatar
HeadsU.P.
Has anybody played with the dizzy hold-down clamp lately?
Old Sep 6, 2018 | 09:04 AM
dyerk's Avatar
dyerk
Sorry, what's the dizzy hold down clamp? Do you mean for the distributor?
Old Sep 6, 2018 | 09:25 AM
HeadsU.P.'s Avatar
HeadsU.P.
Yes. Dizzy = distributor. Is the clamp still tight?
Old Sep 6, 2018 | 12:24 PM
Tim69L46's Avatar
Tim69L46
The person who told you it jumped timing is most likely correct. The backfire probably caused your timing chain to jump a couple of teeth. I wouldn't run it until you figure out whether the timing marks are aligned on the cam and crank gear. Loud knocking is not a good thing hopefully you haven't broken anything.
Old Sep 6, 2018 | 12:25 PM
stingr69's Avatar
stingr69
compression check please.
Old Sep 6, 2018 | 12:56 PM
dyerk's Avatar
dyerk
I think my next step is to pull the front end of the engine apart and check the timing marks.
Old Sep 6, 2018 | 02:51 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
got to love those stock plastic timing gears ! ... NOT !
just go buy a timing chain set, and dig in.
Old Sep 6, 2018 | 03:21 PM
HeadsU.P.'s Avatar
HeadsU.P.
A jumped timing chain is like Big-Foot. I have heard of them, but have yet to see one or even a decent picture of one verifying it.
There would have to be an enormous amount of slop in the chain for that to happen. And for the chain to not strike the timing cover or oil pan is hard to believe.
Old Sep 6, 2018 | 03:36 PM
cv67's Avatar
cv67
St. Jude Donor '05
Edit (re read) Seen 1 or 2 that jumped a tooth, most broke. It is possible for sure though .
Most were stock nylon geared pieces, They could last seemingly forever or 40kmiles.
Would be nice to see a true spring loaded tensioner. Couple here and there that arent so hot attempts.
How hard could it be even if a hole needed to be drilled/tapped. GOFAST you around?
Old Sep 6, 2018 | 10:33 PM
Tim69L46's Avatar
Tim69L46
If it is a plastic timing gear check to make sure you have all the pieces. They can plug up a journal or end up somewheres else you don't want them.
Old Sep 7, 2018 | 07:55 AM
62corvette's Avatar
62corvette
There would have to be an enormous amount of slop in the chain for that to happen and not strike the timing cover or oil pan is hard to believe.
It happened to me on a 1969 Impala in 1976. It does happen.
Old Sep 7, 2018 | 08:04 AM
derekderek's Avatar
derekderek
I missed a shift in my 65 GTO. Wiped out every nylon timing gear tooth. Turned around rolled it down the long hill put it in 2nd gear try to get it to start. I heard it bang through the carb heard it bang it through the exhaust felt it catch then it was dead then it was banging through the carb then it was banging through the exhaust then it would run for a second then it was dead. So yeah these things jump time. I bent all 16 valves. I was 17 at the time and had no idea what I was doing. So I bought a 66 GTO and pulled the 389 out of it. Apparently somebody had stuck at 326 in my GTO already so I didn't miss it much.
Old Sep 7, 2018 | 11:47 AM
sambrand's Avatar
sambrand
its also possibly an intermittent spark issue wither a plug or wire is loose or damaged and not always burning the fuel, this can easily cause the detonation/backfire sound if you have a cat as it tends to collect vapor but as op said it is more probable that its timing related.
Old Sep 7, 2018 | 04:21 PM
HeadsU.P.'s Avatar
HeadsU.P.
Well as usual the forum has formed a posse lynch mob and want to rip the engine out before diagnosing the issues. The O.P. states:
"sounds like drums in a tin can or loud knocking at all RPMs."
If the timing chain truly jumped a tooth or two it would retard the valve and ignition timing, not advance it. So how does one hear drums in a tin can and loud knocking if all the timing is retarded? Any slack in a chain would result in the cylinder firing AFTER the compression stroke if not on the exhaust stroke.
I would be surprised if it ran at all. And if it did, the exhaust manifolds or headers would be cherry red.
So put your tools and away for a minute and think about diagnostics first.
Old Sep 7, 2018 | 04:45 PM
wcsinx's Avatar
wcsinx
...unless the engine was suddenly forced to run backwards for an instant.
Old Sep 7, 2018 | 05:04 PM
69Vett's Avatar
69Vett
with his issues, and symptoms,
I would not leave factory plastic gear, and slack timing chain in place, if they are original.
To Engine knock created after shutdown backfire
Old Sep 7, 2018 | 05:44 PM
HeadsU.P.'s Avatar
HeadsU.P.
You know that would be impossible. O.P. said loud noise at all RPMs. Its still running!
Old Sep 7, 2018 | 05:46 PM
HeadsU.P.'s Avatar
HeadsU.P.
I would not either. But you can't jump to conclusions and throw parts and money at something just because of a hunch.
Old Sep 7, 2018 | 05:56 PM
derekderek's Avatar
derekderek
Okay, get yourself a piece of heater hose. It makes a pretty good stethoscope. Fire the engine and hold one end of hose to your ear. Run the other end across the tops of both valve covers and then go down underneath and running across the oil pan rail lip. Both sides. And maybe take the water pump off see what it sounds like at the front of the engine. In fact, come to think of it, take all the belts off and start it up. That wull rule out any water pump alternator power steering noises. And you might be able to get in there with the pump on and listen to the timing chain cuz you're not going to have a fan blade trying to take your fingers off. if automatic transmission, it could also be a cracked starter wheel making the torque converter Bang all over the place.
