Steering wheel alignment issue
Joey
Joey
eg. Steering wheel is off to the left when driving.
Start with 1/8 sleeve rotation.
1. You need to toe out the left wheel (shorten the left sleeve overall length tie rod to tie rod)
2.Toe in the right wheel (Lengthen the right sleeve overall length tie rod to tie rod)
if the steering wheel is off to the right when driving.
1. You need to toe in the left wheel (lengthen the left sleeve overall length tie rod to tie rod)
2.Toe out the right wheel (shorten the right sleeve overall length tie rod to tie rod)
Start by marking each sleeves position, mark the 12,3,6,9 oclock position so you know how much you are rotating them. I number the 12,3,6,9 positions as 1 , 2 ,3 ,4 so I know where I started. or you can measure from tie rod to tie rod length in case you get mixed up which way you turned them.
Continue with 1/8 sleeve rotation until you are happy with the steering wheel position.
