Loan me a trailing arm bushing install tool?
Old 09-15-2018, 03:52 PM
ScottEwine
ScottEwine's Avatar
Default Loan me a trailing arm bushing install tool?
Does anybody have a trailing arm bushing install tool they can loan me?
Old 09-15-2018, 10:17 PM
grumpy73
grumpy73's Avatar
Try your local parts stores most have loaner tools.
Old 09-15-2018, 10:49 PM
naramlee
naramlee's Avatar
LOL i'd buy you dinner at a high end steakhouse if ANY local autoshops had that in stock
Old 09-15-2018, 10:59 PM
gjohnson
gjohnson's Avatar
McGYVER 101.This is what I used to install and flair
ScottEwine (09-16-2018)
Old 09-15-2018, 11:14 PM
naramlee
naramlee's Avatar
that's just an air hammer attachment correct?
Old 09-16-2018, 06:53 AM
gjohnson
gjohnson's Avatar
yes. Works great
Old 09-16-2018, 12:57 PM
naramlee
naramlee's Avatar
Originally Posted by gjohnson
yes. Works great
wooo I love our ingenuity sometimes ^.^
Old 09-16-2018, 03:54 PM
ScottEwine
ScottEwine's Avatar
My same friend that had the rear bearing setup tool also has the trailing arm bushing tool, so thanks again to my friend Mike!
Old 09-16-2018, 07:03 PM
DUB
DUB's Avatar
Received 2,713 Likes on 2,321 Posts
JUST MAKE SURE that when you stake the inner sleeve. That you take a file or grinder and get ANY of that the sleeve that may be protruding out past the tapered washer FLAT. . You wan the surface of that tapered washer FLAT so your shims lay against it FLAT with nothing pushing out on the shim keeping it from beign flat against that tapered washer.
DUB.
Old 09-16-2018, 09:09 PM
gjohnson
gjohnson's Avatar
DUB.
I did exactly that DUB.Advice from you in another thread related to this.You have helped me w many things
Old 09-16-2018, 10:24 PM
JR333
JR333's Avatar
Great idea on the pointed air chisel !!... but I need to know, did you use air power or just smack it with a hammer ?
I'm thinking carefully a burp at a time will do the nicer job you have. I did the same setup using my two pullers like you have them arranged and for the flare I used the center pin from the puller. The problem happened in my new 12 ton china press the 3/4 inch steel press rod bent sideways like butter. The 3/8 drive socket I used also left a permanent deep imprint in this china steel rod as well
Old 09-17-2018, 10:30 AM
gjohnson
gjohnson's Avatar
Smacked it w/5lb sledge.
Old 09-20-2018, 04:51 PM
ScottEwine
ScottEwine's Avatar
Is there a specification for how much these be should be compressed before you whack it with a hammer? Right now I am at 2.125”
Scott
Old 09-20-2018, 06:59 PM
'75
'75's Avatar
I wrote on my tool to compress to 2.225" between the two tool plates. Not sure where I came up with that measurement, but there are several corvettes running around the area with them and no problems. Edit, I just found an old post that recommends compress it to 2.200 to 2.230"
JR333 The air hammer bit is used backwards, you hit the point with a hammer to flare with the taper that normally goes into the air hammer.
ScottEwine (09-20-2018)
Old 09-20-2018, 07:06 PM
Vette5311
Vette5311's Avatar
Received 1,255 Likes on 838 Posts
Default Use a spacer.....
When pushing a bushing in an a frame (same thing your doing here) I use a spacer to keep it from collapsing. Once this starts you are basicly pressing into a bind. Try tapping it with a hammer to get it straight again. Often times a socket can be used as a spacer to keep it from bending down.
Old 09-22-2018, 07:01 PM
ScottEwine
ScottEwine's Avatar
Like all real Americans I am a member of both the Corvette and AR-15 forums, so I will dial it back to 2.223.
Scott
To Loan me a trailing arm bushing install tool?
Quick Reply: Loan me a trailing arm bushing install tool?
