Help with belt change
Old Sep 16, 2018 | 10:44 PM
Bhebert449's Avatar
Bhebert449
Default Help with belt change
Im getting squeeling in my belts on my 69 427. Not sure which belt but may be power steering. Are there instructions on how to remove and replace belts on a 69 Big block?
Old Sep 17, 2018 | 07:43 AM
Mooser's Avatar
Mooser
Power steering has two places that need to be loosened
One nut under the alternator (sort of) that goes on a stud on the rear of the pump (just above the red cap in this photo)
And in the same location on the front of the pump there is a bolt that needs to loosen, (it's behind the pulley)
You may need to loosen the alternator as well if your alt belt goes from the PS pump up to the ALT)
HIH
M
