First make sure you have them laid out properly, it's very easy to make a mistake. The rods are not straight, they are offset front/rear.
I found installing the side of the hub first was the most convenient way to do it.
The strud rod support under the diff only fits in one way so no problem there.
Re: Strut rod installation - any tips (Twin_Turbo)
Marck
[Modified by Twin_Turbo, 4:56 AM 10/25/2002]
Are you trying to scare the sh it out of me? I just replaced the differential and the stock strut rods with VBP rods. I ran down into the garage and checked my removed stock strut rods. They are symmetrical. The VBP rod were also. No mention in factory manual that the stock rods are not identical. No mention on the instruction sheet from VBP. No offsets anywhere. (1976)
I thought if the rods were not straight, Bubba had bent them to adjust the camber?
