Mcgard wheel lock problem
Old Oct 25, 2002 | 09:18 AM
MikeC's Avatar
MikeC
Default Mcgard wheel lock problem
My parts car that I am buying has wheel locks on it but I have not seen the wheel lock socket. How do I get these off?
This is a big problem as the calipers are seized and need to be removed before I can move it!?!?!?!?!
Old Oct 25, 2002 | 10:20 AM
Gary79's Avatar
Gary79
Default Re: Mcgard wheel lock problem (MikeC)
lock on a pair of vise grips. this is what the thieves use when they steal your wheels and you've got a locking lug nut. don't ask me how i know this.
Old Oct 25, 2002 | 10:33 AM
Neo Fender's Avatar
Neo Fender
Grind two flats on opposite sides of the locking lug. Get a big-azz open-end wrench...
Old Oct 25, 2002 | 10:41 AM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
I've seen some guys heat up the lock and then take a chisel and put it inside the keyway and tap it right off. Makes you wonder if McGards are more visual security than real security.
Dep
Old Oct 25, 2002 | 10:50 AM
72GACRZR's Avatar
72GACRZR
You could try one of those TV one size fits all sockets, but I'd bet on the vise grips. :seeya
Old Oct 25, 2002 | 02:20 PM
kgraumann's Avatar
kgraumann
If all else fails, they make a tool to take these off. I don't recall where you get one, but the local tire shops use them to remove the locks. I have seen them charge around here $8 to remove each locking lug. The reason why it is so expensive, is the tool can only be used 4 or 5 times before it becomes useless.
Old Oct 25, 2002 | 04:07 PM
silver 80's Avatar
silver 80
I had the same problem lost key when I bought the vehicle,
had a friend weld a nut on the lock and just used a socket to take them off.
Old Oct 25, 2002 | 04:43 PM
chevyjeff's Avatar
chevyjeff
try a 13/16 sparkplug socket and a sledge hammer. Hammer the socket over the lugs and twist off. Use of heat is helpful too. You will probably need 2 or 3 sockets to do all 20
Old Oct 25, 2002 | 04:50 PM
Fevre's Avatar
Fevre
Mike
A big pipe wrench might work if you can get it on the head of the lug.
Old Oct 25, 2002 | 07:23 PM
Paul L's Avatar
Paul L
http://www.drivewerks.com/catalog/sh...oolsI_pg23.htm
Old Oct 25, 2002 | 09:57 PM
SharkAttack's Avatar
SharkAttack
Default Re: Mcgard wheel lock problem (chevyjeff)
I hope he only has one lock per wheel! :D
Old Oct 25, 2002 | 10:08 PM
Paul L's Avatar
Paul L
OK, borrow the tool from your local GM dealer. They do these jobs all the time.
Old Oct 26, 2002 | 11:40 AM
SizzleChest's Avatar
SizzleChest
weld a bolt to the lock nut and presto!
Old Oct 26, 2002 | 12:00 PM
carlmb's Avatar
carlmb
Default Re: Mcgard wheel lock problem (SizzleChest)
A 15/16 12 point socket is the size I found that fits snugly over most McGard wheel locks.
If you overtighten the other lugs on the wheel first this will compress the wheel flange and make it easier to remove the locks. Good luck.
Old Oct 26, 2002 | 08:47 PM
MikeC's Avatar
MikeC
Default Re: Mcgard wheel lock problem (carlmb)
Thanks for the help guys,
I think I am going to try the vise grips and if that sdoesn't work I'll weld a nut it them.
I am going to bring a generator there to power my air compressor when I go there to pull everything off of it so I'll just take my welder too.
I don't know why I didn't think of the nut welded on because I have done that to a friends jeeps sway bar bolt( they are a carriage type bolt so you can't get them tight enough sometimes.
To Mcgard wheel lock problem
