69 front suspension rebuild question
So here’s the noob question I have been chewing on - and it’s not so much about the work itself, it’s about supporting the car while I do it. I know where the correct jacking points are. I can see when after I get the spring out and lower arm out it’ll be a little tight removing the upper arm being close to the fan shroud so I was thinking of lowering the car down again because over the fender looks like better access. Also have a low ceiling in my garage and can’t leave the hood open if it’s up on 4 jack stands and would prefer not to remove the hood. Working alone.
It’s the fiberglass body that concerns me. I’ve had the car’s front end up on 2 jack stands placed under the lower control arms, obviously in this case I’d support them under the jack points behind the front wheel. When doing that I put some large wheel chocks behind the rear wheels and left the car in gear with the ebrake on. Only left the car like that for a few hours at a time.Any problem leaving it like that for a longer period of time? I am probably overthinking it because with some of the old cars (Nova, Chevelle …) I wouldn’t have given it a second thought. Again, it’s the fiberglass body I’m wondering about and just trying to be cautious
