Headlight Switch??
Old Oct 25, 2002 | 02:07 PM
GRAYGHOST's Avatar
GRAYGHOST
Default Headlight Switch??
I want to replace the headlight bezel on my 78 which requires removing
the ****/shaft. Does the ****/shaft just pull out of the switch or is there
a release mechanism. I don't want to have to remove the whole switch but I don't want to damage it trying to "pull" the **** out. Help!!!
Old Oct 25, 2002 | 02:15 PM
PrarieShark's Avatar
PrarieShark
From: The cure for the blues is eight cylinders roaring
Default Re: Headlight Switch?? (GRAYGHOST)
There is a small pin on the *** you have to press in to remove it.
Old Oct 25, 2002 | 02:20 PM
GRAYGHOST's Avatar
GRAYGHOST
Default Re: Headlight Switch?? (PrarieShark)
Thanks. Without that piece of information, I would have probably pulled the switch right of the dash!
Old Oct 25, 2002 | 02:26 PM
CHEESERAL's Avatar
CHEESERAL
PrarieShark is right, there's a small button/pin on the switch. If I remember correctly it's close to the dash on top of the switch as mounted. Disconnect the battery or your lights will be on the whole time and that switch gets hot pretty fast. Pull the switch to the on postition and press that button and the rod will come out easy. The tuff part will be finding that button with the dash all together. I did mine when I had the speedo/tach cluster out, it was easy then.
Good luck!
Old Oct 25, 2002 | 02:30 PM
Stewart's74's Avatar
Stewart's74
You do have to venture behind the dash to do this. You have to have access to the area where the two vacuum hoses attach to the switch. Next to the two hoses is a little spring loaded button. Pushing in on the button will allow you to pull the **** and rod out of the switch.
Old Oct 25, 2002 | 02:34 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Default Re: Headlight Switch?? (Stewart's74)
Just take the top dash pad off to replace switch just did it last night.
:rolleyes:
Old Oct 25, 2002 | 03:14 PM
drspeedy's Avatar
drspeedy
Man, getting in there and taking out that headlight switch was awfully fun- maybe you should do it anyway just for kicks :crazy:
-doc
Old Oct 25, 2002 | 03:18 PM
Fevre's Avatar
Fevre
When I re-did my interior I bought a new switch. I hooked it up and tested but after putting the interior back together it did not pop the lights up. :mad Tried getting my hand down in there with just the top dash pad off and no go. :cry Have just used the bypass ever since. :)
To Headlight Switch??
