Gas Tank Cleaning
Old Sep 30, 2018 | 03:16 PM
rodney25's Avatar
rodney25
Default Gas Tank Cleaning
Hi All,
Decided it was time to clean out the gas tank. Can anyone tell me the correct way to clean out the gas tank without damaging anything on the inside? Was told to drain the fuel and use dishwashing soap and water. Is this right?
Old Oct 1, 2018 | 03:06 AM
revitup's Avatar
revitup
No, and what would make you think a gas tank needs to be cleaned out?
Old Oct 1, 2018 | 03:24 AM
GTs 58's Avatar
GTs 58
Has the car sat for 10-15-20 years with old gas in it? Then it would most likely need to be cleaned out. I had two tanks cleaned in a vat at a shop that does radiators.
Old Oct 1, 2018 | 08:09 AM
HeadsU.P.'s Avatar
HeadsU.P.
Rubber bladder / liner involved here?
Old Oct 1, 2018 | 09:02 AM
DUB's Avatar
DUB
Not knowing what year your Corvette is.... is not helping due the gas tank designs changed from 1968 to 1982.
DUB
Old Oct 1, 2018 | 01:03 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Based on past posts it looks like the car is a 75.
Old Oct 1, 2018 | 04:36 PM
sambrand's Avatar
sambrand
never use water and soap, last thing I would want to try is something that could leave a residue behind. especially something that could leave a gummy residue. if nothing else is wrong witht he system such as leaks etc I would drain it completely, and use marine grade cleaner, follow the directions. something similar to this, again NOT WATER
\https://www.wholesalemarine.com/star...oaAtmlEALw_wcB
Old Oct 2, 2018 | 04:54 PM
rodney25's Avatar
rodney25
The car is a 1975. I rebuilt the carb and found a cloudy milky like substance mixed with the good gas in the carb fuel area. When it dried out after a day it turned to this powder like dust light brown to gold in color. I took that carb off and put on a brand new carb (never before used) and after a week found the same substance in the new carb. I then put a camera scope in the gas tank and saw the same thing in the tank. Not a lot but enough to make me wonder. I pulled the tank and dumped all the fuel. On Youtube a lot of posts demonstrate to use water very little dish soap and clean inside well. After wash out well and clean dry with no lint towels. The bladder is still in the car.
Old Oct 2, 2018 | 05:11 PM
sambrand's Avatar
sambrand
I think I was pretty clear on the no water comment, but tis your car and if youtube is the expert by all means go ahead and ruin your fuel lines and brand new carb. im done. (the milky white cloudy soloution is most likely water in old gasoline.)
Old Oct 2, 2018 | 05:29 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Originally Posted by rodney25
Hi All,
Here: Carter recommends water & mild detergent to clean a fuel tank.
https://carterfuelsystems.com/resour...an-a-fuel-tank
Old Oct 2, 2018 | 07:47 PM
lionelhutz's Avatar
lionelhutz
Some soap and water would be fine if you pull the sender unit and wash and rinse it well before drying it well.
Old Oct 2, 2018 | 08:22 PM
rodney25's Avatar
rodney25
I was torn and confused. Took the sending unit out so just the tank and bladder and took tank to a local shop (Very popular and in business for 40 years) and a local auto restoration shop. ( Could not leave the restoration shop, wish I could live there lol). Both said the same thing: Sending unit never touch water. Clean that with chemical wash mentioned earlier. The bare tank and bladder use mild dish washing soap with water (a gallon) and clean inside. The bladder will protect metal of tank. Interesting restore shop said to get marine tape and seal around the lip where the sending unit bolts to the tank. The purpose is to create a seal around the tank and the bladder preventing any water to get between the bladder and the tank. Restore shop said the rubber nature of the bladder will indicate any residue and to be careful. Will try tonight and let you all know.
Old Oct 4, 2018 | 01:47 AM
rodney25's Avatar
rodney25
Ok all complete and worked 100% Tank is squeaky clean no residue grim. Will reinstall sending unit tomorrow and then the tank.
Thanks for all your help and links!!!!!!
Old Oct 4, 2018 | 07:59 AM
Hammerhead Fred
Please let us know if this resolves your residue issue.
Old Oct 10, 2018 | 11:58 AM
rodney25's Avatar
rodney25
Ok reinstalled tank filled tank and test. Put a camera scope in tank to double check. All is perfect, tank is clean as day one with no residue build up or anything. Youtube and 2 auto shops were correct. mild soap (little bit) rinsed repeatedly with water and 100% dried out works fine. Thanks for all your help and input.
Old Oct 10, 2018 | 12:51 PM
stumpshot's Avatar
stumpshot
The hotest water you can get makes a good rinse. Rinse your dishes in cold water next time vs hot water. Quite a difference. Compressed air does a great job of drying also. I"ve used this technique on motorcycle tanks a few times.
Not a thing wrong with hot, soapy water. Experts are always expert at something they've never done before.
Congratulations on your job.
To Gas Tank Cleaning
