1968 Conv. Rear Deck Lid Adjustment
Location: Loud, Raw and Dangerous 1968 327 4S in Southern California
Looks like I have a few options to try to get rid of the significant extra height on the rear of my deck lid (see attached picture and description): 1) Adjusting the front side, 2) adding or deleting spacers under the attachment of the lever arm in the very back or 3) force bending the arm down. I tried option one to adjust the front side with spacers but did not bring down the back much. Option two looks to be a bit complicated but might be the last resort if option three does not look feasible. Option three is to bend the rear arm...has anyone done this and if so how? I am just a bit worried about the possibility of damaging something with this option.
Thanks,
Redvette2
About 1/2 inch too high in the back and 1/8 inch too low in the front. No weather strip installed.
Thanks,
Redvette2
Redvette2
Here is a closer look...no shims just the large box the hinge assembly sits on. Beginning to think bending the arm might be the only choice. However have to be careful in doing so that the lid does not move too far forward as well.
Redvette2
Hinge assembly mounting...spring behind it.
Redvette2
Bending anything to get it to fit just doesn't sound right. Are you sure the shims are not under the bracket?
Take a look to see if the outer skin (top of the deck lid) is de-laminated from the bottom of the deck lid assembly. Mine is de-laminated on the passenger side and sticks up a bit
tfringo (08-20-2021)
2018 C3 of Year Finalist
Thinking you should get new hinges and maybe springs while you are at it . There’s no adjustment for that .
expand the spring shove it full of wooden shims close the lid the spring will fall off.
The first year of this new model corvette were known for their poor fit so maybe this is just the way it came. Also this car is a Frankenvette with parts from various years so who knows what has been done to it. Thanks for the ideas to check out!
Redvette2
Found a gap and corrected but still high.
Yes...that is what I ended up doing. I put three washers on each bolt between the front brackets and the lid. With the new weatherstripping in place it does not look too bad. Tape is just to hold the weatherstripping in place for evaluation before gluing. Too worried about bending parts on a 50 year old car.
Edit update:...the spacer under the rear hinge front bolt worked much better (post 15). Took out the washers on the front latch bolts and everything looks perfect.
Redvette2
Redvette2
It almost appears that your hinges may have been bent back over the years. That is a huge difference between your deck lid and the rear deck. Something is not right. I know '68's fit and finish was bad but I really doubt Chevy would let that out of the factory.
My '71 deck lid is perfect (except for my de-lamination on the passenger side as I mentioned) and it's got a few shims where the deck lid bolts to the hinges.
Redvette2
Issue Resolved....Easy Fix
Took another look at the misalignment as it was still bugging me. I noticed that the hinge bracket where it connects to the deck at the rear was not totally flat and had a curved edge on the rear back edge (See post 7 picture above). Placed 3/16 inch spacer under the deck on the front bolt only as suggested and now the deck sits perfect! Yahoo...thanks for the idea!
Edit Update: Took a look at the AIM, page H110, Lid Control and Lock ASM and it shows a shim (item 17) placed in the exact same location. This was missing on my car.
Redvette2
Redvette2
theandies (12-14-2018)
