12 gauge wire for atenator where to buy
Old 12-11-2018, 11:00 PM
Oldguard 7
Oldguard 7's Avatar
Default 12 gauge wire for atenator where to buy
Where can I buy red 12 gauge (3.0 metric) wire that connects to the power lug at the rear of the alternator? Also, does anyone know what the size of the non insulated eye terminal that fits over the lug as well as the rubber boot that covers the lug nut?
Old 12-11-2018, 11:36 PM
carriljc
carriljc's Avatar
This kit will probably provide everything you need:
http://www.madelectrical.com/catalog/alt-1.shtml
and here's the boot:
https://www.corvettecentral.com/c3-6...s%26count%3d18
If it was me I'd just go get some automotive wire and lugs at the car parts store (or go to the pick-a-part and get everything) but this looks like a pretty complete kit. Be aware that you probably want to use that 8-gauge sized wire at the alternator output. Hope that helps.
Old 12-12-2018, 07:31 AM
Gordonm
Gordonm's Avatar
I agree with this. Depending on your load you may need bigger wire. I run a separate terminal block for my fans, computer, Vintage Air system that are being feed off a #8 wire from the alternator terminal. I left the factory harness alone but wanted plenty of power for everything else. Minimum would be 10, 8 is better. Never to big but to small it can overheat.
Old 12-13-2018, 08:15 AM
Rotonda
Rotonda's Avatar
I believe that your 79 originally had a 10 ga wire from the alternator (at least that's what my 77 had). I would use nothing smaller than 10 gauge, and would recommend 8 ga. I am running 6 ga with my CS130D alternator.
Old 12-13-2018, 08:29 PM
Crimson Thunder
Crimson Thunder's Avatar
Do you have a car stereo store in your area? That is usually the best place to get good quality #8 AWG wire and terminals.
To 12 gauge wire for atenator where to buy
Quick Reply: 12 gauge wire for atenator where to buy
