Data Plate Missing
Old Oct 8, 2018 | 11:10 AM
Atindell's Avatar
Atindell
Default Data Plate Missing
Did GM keep vehicle info like Pontiac? Bought a Corvette and the Data Plate is missing. Want to know what the car was originally.
Old Oct 8, 2018 | 01:05 PM
NRAROX's Avatar
NRAROX
Depends on the year. What year is your car? C3s are generally reliant on documents attached to or housed in the car.
Old Oct 8, 2018 | 01:08 PM
vettebuyer6369's Avatar
vettebuyer6369
Are you calling the trim tag, found in the LH door jamb, a "data plate?"
This didn't have much more info than paint/interior colors. Does not include the kind on info found on other type car "data plates."
Old Oct 8, 2018 | 01:12 PM
7T1vette's Avatar
7T1vette
Original exterior paint color and original interior color can usually be identified from 'hidden' areas that are not normally repainted (under sill plates, behind door panels, under carpeting, etc.). The only info on the trim tag is the exterior color, the interior color and the build date.
Old Oct 8, 2018 | 02:47 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If you're looking for the options/codes sticker found on C4s and later cars, C3s did not have them.
Old Oct 8, 2018 | 06:09 PM
Atindell's Avatar
Atindell
Originally Posted by nrarox
depends on the year. What year is your car? C3s are generally reliant on documents attached to or housed in the car.
1966
Old Oct 8, 2018 | 06:13 PM
Atindell's Avatar
Atindell
Yes, I'm used to my 70's Muscle that between the VIN and the Data Plate (Trim Tag) I can tell you everything about the car.
Old Oct 9, 2018 | 08:41 AM
Bikespace's Avatar
Bikespace
Have you looked for the tank sticker? It may be gone or unreadable, but there was a sticker applied to the top of your gas tank that would have all the information you want. Search the forum for the best way to confirm its presence (borescope) and retrieve it (drop the tank).
I don't know if 1966 had a tank sticker, though.
Old Oct 9, 2018 | 08:46 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by Atindell
1966
You will need original documentation with the car. 66s did not have tank stickers. Vehicle information tags should be on the support bar under the glove box. You might want to post in C2 for additional information.
To Data Plate Missing
