Seat Cover Replacement
Old Oct 26, 2002 | 09:24 AM
jhorlocker's Avatar
jhorlocker
6th Gear
Default Seat Cover Replacement
I need to replace the seat covers in my '81 vette. I was looking at the price difference between buying the new covers or buying the supplies and recovering them myself. Has anyone done this, and how much work is it? The cost of the materials is about 50% of the cost of purchasing the new covers already done. I was also told 2 different things about the seat foam - one person told me to replace the foam when I redo the covers, another told me to just buy the material and reuse my current seat foam. What do you guys think? :jester
Old Oct 26, 2002 | 10:04 AM
Paul L's Avatar
Paul L
Default Re: Seat Cover Replacement (jhorlocker)
I really believe this is a job left to the professionals. Buy the cushions with new foam and pop them in.
http://www.alknochinteriors.com/welcome.htm
[Modified by paul79, 9:06 AM 10/26/2002]
Old Oct 26, 2002 | 10:14 AM
paintdaddy's Avatar
paintdaddy
Default Re: Seat Cover Replacement (paul79)
I just asked this in c4.The same answer I got everytime was to replace the foam. As far as to have them pre-installed when you purchase them ,I think on a c4 they can be snapped in to the seat frame.On a c3 they still have to be Hog ringed on to the seat frame.Not for sure but this is what i have heard. :seeya
Old Oct 26, 2002 | 10:19 AM
Paul L's Avatar
Paul L
Default Re: Seat Cover Replacement (paintdaddy)
The Pace Car type seats snap into the plastic seat frames via elasticized wires/cables on the back of the cushions.
Old Oct 26, 2002 | 02:06 PM
my2crazyeyes's Avatar
my2crazyeyes
I am planning on doing the same thing this summer, and had the same question about the foam. Why would it need to be replaced if it doesn't seem that bad? is there a difference between the material used in either?
Thanks for any help
Old Oct 26, 2002 | 04:23 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
I would think that replacing the foam is just a good common sense thing. I think if you're going to go through the cost and time of replacing the seat covers, while you're at it, you might as well replace the foam. Even if it doesn't "seem that bad," you never really know until you do a back to back comparo. I bet new foam feels mighty nice.
Old Oct 26, 2002 | 08:14 PM
my2crazyeyes
The main reason why I asked is because I am a college student, and money is tight, but I want to be able to do some cosmetic type of things to my car, after looking at the prices at willcox on seat covers it seemed like something I could do this summer, but if I have to get new foam too that will be getting a little out of budget, so if I could get away with using the old foam. what kind of feeling does the new foam have? is it softer? or is it just thicker so that there is more padding? is there anyway of telling by measuring the thickness of the old foam or something wether it's reusable or not? If I could get away with not buying the foam I would be able to put new carpeting in, which she needs badly. Thanks for the help though, it does make sence to replace it while I have the covers off
Old Oct 26, 2002 | 09:18 PM
Paul L's Avatar
Paul L
Default Re: Seat Cover Replacement (my2crazyeyes)
If the foam has ever been wet for whatever reason, such as wet shampooing, it will smell from fungus growth on the foam. Musty smell in a Corvette? That is the reason.
Old Oct 26, 2002 | 09:51 PM
jimiscnc's Avatar
jimiscnc
I think the erplacing is pretty easy, you just position and stretch the seat and clip wit hog ring pliers, which is a heavy stape that ggeets bent into a closed circle after being pierced into the seat material and wrapping arounf a ring framework on the seat frame.
even though the foam seems kind of expensive, if youre going to the trouble of seat covers, you should replace the foam.
in other words, seat cover replacement is well within the capabilities of the average guy that has a $12 set of hog ring pliers.
Old Oct 27, 2002 | 11:39 AM
fontking1a's Avatar
fontking1a
I did mine myself about twenty years ago. I bought some used later model seats with the foam and dark blue leather in rather "ratty" shape and re-covered them myself using some black leather, two different grains that I had lying around my shop. Upholstering is fun and there's nothing like doing stuff yourself....just for the learning experience. If nothing else, you'll appreciate those who do this work professionally. I taught myself to sew and it wasn't that hard. It's probably cheaper to buy the seats already done, but....it's not as much fun as doing the whole thing yourself. By a commercial sewing machine (used) on e-bay and you'll have it for life and then you'll be able to do upholstery work yourself and for your friends. That's what I did and the money I made more than paid for the machine.
Old Oct 27, 2002 | 11:56 PM
feb18blacksunday's Avatar
feb18blacksunday
From: Boone NC home of 3peat National Champs ASU Mountaineers
Replaced mine this spring. Not too hard get some good wire cutters to get the hog rings off though. If the foam isn't messed up too bad use it I did. Mine looks great. Fun thing to do while the snow is falling.
Thanks for any help
Old Oct 29, 2002 | 11:34 AM
CORVETTE CRAIG's Avatar
CORVETTE CRAIG
Jlocker,
Seat covers are always an issue with Vette owners, a true common problem for most of us. Spending way too much time looking/searching for the best possible deal, I replaced mine two years ago with fantastic results. http://www.anthonysupholstery.com in Tampa has seat covers within your budget range. They offer free embrodiery on the headrests in different cross flag logos (way cool) and I went with the imit. leather, for under $200.00
Note here about the foam, THEY suggested taking a iron and STEAMING the foam before replacing it, it will BOUNCE back to life, and they were right!!!
On the installation side, I went with a local sew lady, for $75.00.
In short, the total for both were $275.00.
Good Luck, and I hope that web site I gave you is working, if not you'll need to run a search.
Old Oct 29, 2002 | 12:16 PM
phoenix's Avatar
phoenix
Default Re: Seat Cover Replacement (CORVETTE CRAIG)
My seats were recovered 7 years ago (6 before I bought the car) but the foams were not replaced.
Now the foam is degrading and the particles are getting everywhere. So even though my covers are nearly mint, I've got to replace the foam. Bubba strikes again.... replace the foam.
To Seat Cover Replacement
