Drone Killer Exhaust Inserts Worked!
Old Oct 10, 2018 | 02:00 PM
Redvette2's Avatar
Redvette2
Default Drone Killer Exhaust Inserts Worked!
Car came with a way too loud Turbo exhaust installed and the low RPM drone really rattled my brain. So I ordered a set of Car Chemistry exhaust inserts from Summit thru ebay for $113 including shipping. For my car the three disk, 2 1/4 " model was the one I selected. Arrived in two days and I installed in the outlet pipes half way into the muffler itself (see picture). Put the supplied inlet cap with the hole on the engine side of the insert. Drilled a hole in the insert outside rings and thru the back of the chrome tips and used a screw to temporarily hold them in (will tack weld when evaluation is finished).
Drone is 90% gone, car sounds real cool and accelerates well. Overall exhaust sound in general is a bit lower and maybe the car is a tad slower, but for me not racing, it solved the noise problem.
Edit update: Took the car for a good run this afternoon and it ain't any slower! Love the sound...reminds me of a past Harley. Going to tack weld it in.
Redvette2
Insert in outlet of muffler exhaust pipe.
Old Oct 10, 2018 | 02:45 PM
zwede's Avatar
zwede
Old Oct 11, 2018 | 06:41 AM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
I used the same inserts, but up near the header collectors. They helped cure my exhaust drone too without a noticeable change to performance.
Old Oct 11, 2018 | 11:02 AM
Redvette2's Avatar
Redvette2
Yes if the muffler did not work I was going to put them up front. I will only use a dab of weld in case I change my mind, but right now I am pretty happy.
Redvette2
Old Oct 11, 2018 | 11:42 AM
zwede's Avatar
zwede
You can use a pop rivet instead of weld. Easy to remove if needed.
Old Oct 11, 2018 | 11:59 AM
Redvette2's Avatar
Redvette2
Good idea....thanks.
Redvette2
To Drone Killer Exhaust Inserts Worked!
