Good day at the track
Old Oct 28, 2002 | 11:49 AM
GDaina's Avatar
GDaina
Default Re: Good day at the track (Flareside)
Assuming the block is new, then std. bore....yea..around 480+ cubes....lot of cubes for the cost of nothing.
Old Oct 28, 2002 | 08:40 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Oh...... NOW I see.......
4.25 STROKER..........
Missed that little part!
So I guess we have a ZL1 on steroids!
Even more sneaky!
LOVE the car. You got a ten sec. ride if you can hook it up. A little more gear couldn't hurt either!
JIM
Old Oct 28, 2002 | 08:45 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: Good day at the track (427Hotrod)
that is one impressive ride you got there,great times too. :yesnod:
Old Oct 28, 2002 | 09:44 PM
ZL1powr's Avatar
ZL1powr
FlareSide ...The displacement is 489.4 with 4.45" stroke and 4.281" bore. GDaina ... The block was allready notched but still required some additional clearancing.
Old Oct 29, 2002 | 01:58 AM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default Re: Good day at the track (ZL1powr)
Yea the stroker part got by me also, I assumed it was a 454. That car would be a good canidate for a ROD. I run 3.70's with my ROD and it is perfect.
Old Oct 30, 2002 | 12:38 AM
ZL1powr's Avatar
ZL1powr
Default Re: Good day at the track (69 N.O.X. RATT)
I have been considering a ROD. Which gear ratios are you running in the trany?
Old Oct 30, 2002 | 01:08 AM
Glenn454's Avatar
Glenn454
ZL1powr, Have you ever weighted your corvette? I't has to light, 3050lbs or so.
Old Oct 30, 2002 | 01:15 AM
69 N.O.X. RATT
1st 2.77
2nd 1.89
3rd 1.46
4th 1.19
5th 1
6th .62
There are different first and sixth gear ratios availible. We are making similar HP and I think any lower in 1st would be to low. It might be better for all out drag racing, but for street use any lower would not be good. I like the .62 in 6th. Richmond will tell you it is not a real strong gear and you should not romp on it. I like it because I can cruise at 80 mph at 2300 rpms. 5th gear maxes out at around 150 and I have no desire to drive a C-3 any faster than that anyway. For my set up the ratios I have are perfect.
[Modified by 69 N.O.X. RATT, 5:16 AM 10/30/2002]
Old Oct 30, 2002 | 02:55 AM
GDaina's Avatar
GDaina
3.27, 2.12, 1.57,1.23, 1.00 in the Doug Nash 5 speed
Old Oct 30, 2002 | 10:15 PM
ZL1powr's Avatar
ZL1powr
Default Re: Good day at the track (Glenn454)
Havn't weighed it yet but I am guessing about 3200. With the iron 454, aluminum heads, copper radiator, and 1/4 tank of gas it was 3370. The ZL-1 block weighs 110 vs 270 for the iron block and I now have an aluminum radiator with spal fans.
