Question for you BB guys
Old Oct 26, 2002 | 11:22 PM
ImBatman's Avatar
ImBatman
Default Question for you BB guys
I have a line on a 454 std block that spun a rod bearing. It knocked a whole in one of the cylinder walls. He said that a machine shop said it is an easy fix to sleeve. He is asking $250 for it.
What does a sleeve cost?
I have a set of 14011034 sb bow tie heads along with a 3502blt block and crank. He is willing to do a trade. The stuff I have will probably never be used and is collecting dust. What do you think worth it or not? :cheers:
Forgot to mention he is not far from me and offered to let me see it before dealing.
[Modified by BlackRat, 9:23 PM 10/26/2002]
Old Oct 26, 2002 | 11:50 PM
Bob Turner's Avatar
Bob Turner
Default Re: Question for you BB guys (BlackRat)
BlackRat,
I would make sure that the block is good before completing the deal. MAKE SURE that the machine shop that you take it to will do the sleeve correctly. Other than that, go for it.....(I bought a block for $200 with a BAD sleeve install, and didn't find out for a couple years...... ) :mad
Bob :cheers:
Old Oct 27, 2002 | 12:39 AM
GDaina's Avatar
GDaina
labor to resleeve a cylinder, around here, is 80 bucks, and the sleeve is around 40.00
Old Oct 27, 2002 | 01:10 AM
71vettman's Avatar
71vettman
generally it is an easy fix. You have to be positive that its been magnafluxed and no cracks were found in the block. Sounds like they may have done that already, make sure you find out though. In the machine shop I work at its about 100 dollars to sleeve. It sounds like it might be a a pretty good deal but be careful.
Kevin
To Question for you BB guys
