Carter AFB?
Old Oct 27, 2002 | 09:09 PM
conway62's Avatar
conway62
Default Carter AFB?
I recently purchased my 71 BB. It came with a Carter AFB Rebuilt carb on it. I cant seem to identify anything about the carb. Im not sure how to tell what CFM it is and if it is correct for the car. My engine is a 454/425hp with LS6 aluminum manifold and cast heads. Any one have a carter on there vette and know anything about these carbs?
Thanks in advance
Old Oct 27, 2002 | 09:31 PM
Oldguard 7's Avatar
Oldguard 7
Default Re: Carter AFB? (conway62)
BB chevy? 800cfm
Old Oct 27, 2002 | 11:14 PM
dman535's Avatar
dman535
The carbs are pretty easy to tune. They are still beeing made by Carter and Edelbrock. The only bad thing I can say about them is that they are sensative to hard cornering and hard braking.
Not sure what CFM ratings them came in from the factory.
Old Oct 28, 2002 | 01:30 AM
72GACRZR's Avatar
72GACRZR
Carter Carbs were on some '70-72 Corvettes. The date codes are A=jan, B=feb etc, except I was not used so J=sep. The 3 following represents the year ex. C1= March 1971 build date.
I remember recently reading that someone had bought carter out, can't remember where. Found this web page on a search, maybe it will lead to more. http://www.carburetorfactory.com/expvw04.html
:seeya
Old Oct 28, 2002 | 06:37 AM
Apeiron's Avatar
Apeiron
Default Re: Carter AFB? (72GACRZR)
Federal Mogul bought Carter a while ago. At some point Carter also sold the designs to their carbs to Weber who are casting them for both Carter and Edelbrock.
Old Oct 28, 2002 | 10:10 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
there should be a number stamped on the passenger side of the carb near the base in front of the the mounting bolt hole. post that number and i will try and help. :chevy
Old Oct 28, 2002 | 02:38 PM
conway62's Avatar
conway62
Default Re: Carter AFB? (clem zahrobsky)
Thanks for all the replies.. I will check for a number and post tonight
Old Oct 28, 2002 | 08:38 PM
conway62's Avatar
conway62
There is a number on the lower right corner of the carb base.
2419 9635SA
I cant find anything else.
Old Oct 28, 2002 | 09:24 PM
clem zahrobsky
Cruise-In I Veteran
9635 is a after market AFB for GM cars and it is 625 CFM :chevy
To Carter AFB?
