!972 Rochester 7042203
Old Oct 30, 2018 | 07:09 PM
fastimes's Avatar
fastimes
St. Jude Donor '19-'20-'21-'22
Default !972 Rochester 7042203
If I were to search for the correct carburetor for my 72, which was manufactured approx. Oct 25th, 1971, what date codes would I be looking for on the carb?
I know the correct part is 7042203, but I see folks searching for date correct carburetors. The date shouldn't be an exact match to the cars manufacturing date should it?
I would think the carb should have an earlier date than the car. I'm just curious about how one calculates the correct date code.
Any input is appreciated.
Thanks!
Old Oct 30, 2018 | 10:28 PM
lars's Avatar
lars
If your car was assembled ("born on") October 25th, the carb can have been built as tight to that date as 1 week (although not common), but usually 2 weeks or more prior to the build date. It's not likely that it would have been built more than a few months prior to the vehicle assembly date. Keep in mind that the carb was installed to the engine at the vehicle assembly plant, and not at the engine assembly plant, so the carb and the engine would have been built in parallel and do not have to be in sequence, as long as neither date is after the vehicle assembly date or much less than 1 week prior to the "born on" date.
Lars
Edit 10/31:
I just realized that your car's "born on" date makes it a very early production car. Since the 7042203 is specifically a '72 carb, you actually don't have to worry about getting one that's built "too early," since your car could have used any carb built for the '72 model year up until about a week prior to your assembly date.
Old Oct 31, 2018 | 09:14 AM
old_vette's Avatar
old_vette
Default '203 Qjet
I have a couple of the '203 carbs available. I can dig these out to verify date codes, if interested. I also have some '202s for the 72 automatics. $100.
Jack
Old Nov 30, 2018 | 01:35 PM
fastimes's Avatar
fastimes
Thanks Jack.
I guess I would be looking for a 7042203 with a date before or in October 1971 as the estimated build date for my (1972) car is Oct. 25, 1971.
As Lars posted, I don't think I need to worry about having a date code that's too early as my car is an early production number (05678)
Old Dec 1, 2018 | 09:41 AM
redrdstr72's Avatar
redrdstr72
Thanks!
Hi Fastimes.
I see you have identified the needed part number for your car as 7042203. This part is specifically for the base engine (350ci/200hp) with manual transmission and without A.I.R. (air injection reactor) system. There were a total of 7 different carburetor variations for 1972 model year.
I thought I'd post this to help make sure you're on the right path as you conduct your search. You've gotten great advice already on dates. NCRS judging guides give a 6 month to (I think) 2 day advance dating vs build on most components. As has been pointed out, this component should be in advance of your engine's build date. If you don't already know, your engine's build date is coded on the cylinder casing's stamp pad.
Hope this helps...
Old Dec 1, 2018 | 10:36 AM
fastimes's Avatar
fastimes
Originally Posted by redrdstr72
Hi Fastimes.
Hope this helps...
Thank you. That's exactly what I have . . . Base 350 (200hp), 4-speed, no A/C, not A.I.R.
The Quadrajet that is on the car is a replacement, Lord knows where that came from. I can't can't find numbers matching that thing anywhere online.
Hopefully finding a properly dated carb for an early build 1972 won't be too hard (or expensive).
Old Dec 1, 2018 | 06:09 PM
Joe79Vette's Avatar
Joe79Vette
They are out there. My 72 was born on Aug 24 of 71. Very early. It took me a year to find one because it is so early. Look on eBay etc. or post a wanted ad here. I have a couple extra 7042203 carbs. Let me check the dates.
Joey
Old Dec 1, 2018 | 07:31 PM
lars's Avatar
lars
I can't can't find numbers matching that thing anywhere online..
Post the number and a photo and I'll tell you what it is.
Lars
Old Dec 1, 2018 | 07:58 PM
redrdstr72's Avatar
redrdstr72
Joey
Hi Joey.
Not to highjack "fastimes'" thread but in hoping it helps him find the right carb for his engine:
My car is only 1 day older than yours (build date August 23, 1971) and its known-original carb is dated G1.
Hope this helps.
Old Dec 2, 2018 | 12:14 AM
fastimes's Avatar
fastimes
That is cool. My carb is dated G1 as well.
I looked and I have 3- 7042203 carbs. They are dated
K1, A2 and D2. So none will work for a Oct car.
Joey
Thanks for looking. I appreciate it.
Old Dec 2, 2018 | 12:27 AM
fastimes's Avatar
fastimes
Lars
Thanks Lars. Here is the number on my carb, the 6th and 7th characters are not legible: "71112?? FA". Bottom number 0951
I have past service records showing that the original carburetor was replaced with an Edelbrock, then a few years later replaced with this Quadrajet.
I tried researching the number online, but came up with nothing. Any info you may have would be appreciated.
Old Dec 6, 2018 | 12:22 AM
fastimes's Avatar
fastimes
Can anyone ID this carb based on the photos?
Old Dec 16, 2018 | 05:53 PM
fastimes's Avatar
fastimes
Bueller . . .
Old Dec 16, 2018 | 06:58 PM
lars's Avatar
lars
It's a commercially rebuilt "mix-n-match" carb where the builder has hacked together several carbs from different years. The float bowl is a 1971 Chevy (built the 95th day of 1971). They mixed this with a 1972 - 74 airhorn and choke system. You don't have any photos showing the throttle plate, so I can't tell you what that is, but you have a messed up carb pieced together and hacked pretty bad... Time to look for a good carb...
Lars
Old Dec 16, 2018 | 07:28 PM
fastimes's Avatar
fastimes
Thank you Lars! I appreciate you giving me that info.
From my records, I know the original carb was pulled and replaced with an Edelbrock. They ran that for a few years and put this Frankensteined Rochester on it.
I'll start my search for a proper 7042203 for my Oct. 1971 build date.
Old Dec 16, 2018 | 07:56 PM
lars's Avatar
lars
Watch out for those commercially rebuilt carbs - lots of them out there, and they're junk...
Lars
Old Dec 17, 2018 | 12:03 AM
fastimes's Avatar
fastimes
Lars
Hopefully I'll get it out of there sooner than later
To !972 Rochester 7042203
Old Jan 12, 2019 | 11:52 AM
fastimes's Avatar
fastimes
Lars
Lars, another member has a 7042203 with a date code of 2156. Would that work for my Oct 25. 1971 build date?
Old Jan 12, 2019 | 12:10 PM
Joe79Vette's Avatar
Joe79Vette
That code means 215th day of 76. Must be a over the counter replacement.
Joey
Old Jan 12, 2019 | 12:12 PM
fastimes's Avatar
fastimes
Thank you Joey!
