Chevy Big Block Pinging
Old Nov 2, 2018 | 01:38 PM
Captain Redbeard's Avatar
Captain Redbeard
1st Gear
Default Chevy Big Block Pinging
I've got a 71 chevy 396 in my truck, and it runs pretty well and seems to been pretty well timed. Except, when I accelerate under load (up a hill most often) it begins to "ping," which is a case of detonation I guess. Does this mean that it's a combination of low octane and slightly too advanced timing? Thanks for the help!
Old Nov 2, 2018 | 05:13 PM
Tim Ware's Avatar
Tim Ware
I had the same problem with my 71 Corvette 454. Today's fuel is bad, but I eliminated all pinging by installing a MSD ignition & coil.
Old Nov 2, 2018 | 05:23 PM
MelWff's Avatar
MelWff
what does "pretty well timed" mean in actual numbers?
what is the initial timing with vacuum disconnected?
is the distributor stock?
how many miles on the engine?
Old Nov 2, 2018 | 05:24 PM
HeadsU.P.'s Avatar
HeadsU.P.
Actually, Ethanol has a higher octane value than the former gasolines. But, yes, it is awful stuff.
What's your advertised compression ratio now? Where is your total timing set at?
You may have to kick it up a notch on your octane purchase choice and / or reduce overall timing a smidge.
Old Nov 2, 2018 | 09:17 PM
derekderek's Avatar
derekderek
There were no low compression 396's. The 1 year only 2 bbl sta wagon engine was 9 to 1. And they used a 122cc head to get it that low. You need to retard the advance til it stops. You. Are probably around 34-36 at 3000 right now. Good for performance car. A lil high for a truck under load.
Old Nov 3, 2018 | 02:26 AM
Strokemyaxe's Avatar
Strokemyaxe
If it’s pinging, you simply have too much timing for your fuel. Couldn’t say which needs to change without knowing everything about your engine. If you have lower compression (which you probably do) you should just set the timing for regular unleaded. Check your numbers. If you don’t ping at WOT and only at light throttle/light load in higher gears, it may be your Vacuum advance is putting a little to much in. May need to fix your vacuum can degrees. Check that you are plugged into manifold vacuum.
-Stroke
Old Nov 3, 2018 | 06:19 AM
HeadsU.P.'s Avatar
HeadsU.P.
In laymans terms, "ported vacuum" is emissions vacuum. He needs a full vacuum port..
Old Nov 3, 2018 | 10:37 AM
Strokemyaxe
ha! Omg I know that. I can’t believe I said “ported”. Smh
Old Nov 3, 2018 | 10:39 AM
dmaxx3500's Avatar
dmaxx3500
we used to ''wash'' em out by running eng and pouring aa little water thru the carb at a fast idle
it would wash out all the carbon
Old Nov 3, 2018 | 06:51 PM
HeadsU.P.'s Avatar
HeadsU.P.
Its the Egg Nog talking. Back off a couple sips.
Old Nov 4, 2018 | 01:00 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
A proper curve would probably fix it if you knew where you are at right now........
A proper curve is the #1 tuning trick there is.....and dirt cheap if done right......like $10
Once a proper curve is realized....you can set the total and initial.
Then work on the vacuum curve.......does your distributor have an adjustable vac can? This could help eliminate pinging under load as well. But you need to get the mechanical part right first and lock it in....then play with this.
Jebby
Old Nov 4, 2018 | 03:57 PM
7T1vette's Avatar
7T1vette
When you stab the throttle, engine vacuum goes way low and the distributor advance can should retard the timing sufficiently. If it does not, your advance can might be faulty. Connect a timing light to see how timing reacts when you 'pop' the throttle (timing should retard). If that is working OK, perhaps the transmission didn't downshift as it should have...or YOU didn't downshift as needed.
If advance can is working OK and the same thing happens on FLAT ground, you need higher octane fuel and/or need to retard the ignition timing somewhat.
To Chevy Big Block Pinging
