Best aftermarket Transmission Crossover.
interpon (10-25-2021)
Looks like top quality in the photos.
What is your opinion with the welds, finish and craftsmanship?
Is it painted or powder coated?
Keep us up to date regarding the fitment and installation of all your hardware.
Im planning to purchase one after the Holidays and it would be nice to have someone's recommendation I can trust.
Thanks, Greg
Thanks, Greg
Thanks, Greg
Thanks, Greg
Heavy... This I do not like, If i could have purchased in in aluminum for a few hundred dollars more I would have.. 27 lbs with nuts and bolts and hardware... I will weigh what we removed when done, then post.
OldCarBum (11-17-2018)
76strokervette (11-18-2018)
Ok.... good concept, BAD followthrough...
The problem ... well several actually, but the one being addressed in this post, is that the exhaust pipe feedthrough is in the friggen wrong place! It is set out wider, further from center both sides, then the stock. There is very little room to get the pipes up high enough to not scrape the ground, with this crossmember in its standard form it moves the exhaust pass through to far to the outer edges and away from the transmission where you can tuck the pipes up and out of the way... if left in stock form the pipes would hang about 2" lower... what a friggen lousy followthrough on a great idea.,
more pictures to follow... by cutting it down and moving it in center, I will be able to run my 3" mandrel bend pipes through it and not give up and ground clearance....
I will also be fixing the weak not thoughtout link/attachment to the side frame rales..
Center pice where transmission mount is... to wide, had to cut down
Different angle of cut down center pice
Frame where old cross member was cut off
Frame where old cross member was cut off. other side.. and yes, we will be replacing the fuel lines
view of cuts
small center box that is removed
ready for welding
ready for welding in this form
close up
different angle
view of cuts
ready for welding
close up
different angle
pauldana
Do you have any more pics of this completed cross-member?
How you attached the outboard ends and fabricated the replacement mounts?
I am pondering getting one because I was thinking the further outboard "pass-under" would make more room for my planned 200-4R.
Looking at all the work that did here I might be better off just buying a piece of channel steel if it's necessary to fabricate that much????
pauldana
I can put the car on the lift tonight and post a few pictures...
when i get home...
the reason I had to cut it up is it did not match the exhaust piping I had/have i run 3" mandrel bend SS.
another day/….
welded, that’s what my sons did, they welded the ends on the frame,
cut the end of the tubing, sleeved it and then put in a hole for a large bolt…
carriljc (10-25-2021)
pauldana
Many thanks..... Great pics! I see how you did the ends----so I'm guessing the vertical bolts on the stock automatic crossmembers don't do much of anything but "align"? Most of the weight is supported by the horizontal bolt? I can do that.
If someone can use the aftermarket cross-member without redesigning, then this seems like a good option
For that matter; the "side" stubs I left for my removable crossmember are longer than that.... wonder if I could cut the ends off that aftermarket crossmember (there goes my no-modification idea?) and slide within, and then bolt on???
I you have time could you give us the height & width of this crossmember? If I can easily modify to slide into the remaining stubs it makes everything a bit easier.
#33
Just looking at my GForce crossmember, I should be able to use it for my bb with 3” exhaust without any modifications.
They do sell several for C3 Corvettes so you might want to give them a call and see which model will function best for you.
When I called them they were extremely helpful and their customer service was awesome.
#34
OldCarBum
So you must have an Automatic to begin with? Can you take height and width measurements? I'm curious if it is a skosh smaller than stock. Hopefully I could slide it into the stubs I left for my crossmember.....
#35
OldCarBum
It will depend on which transmission you will be running as to which crossmember you order.
If your running a TKO-600 like me, the RCC-300 should be the crossmember you would use.
If your running a different transmission, then the measurements from mine will be different than the model crossmember you need.
Give GForce a call and confirm which crossmember you need, they make 3 for 68-81 C3s
I can measure mine for you, I’ll just need to pull it out of storage.
What areas do you need measured?
#36
OldCarBum
Thanks. Below is a pic of the height and distance I am curious about. The square tubing before the attachment brackets ae welded on.
And if you could also the following measurements:
Overall width
WIdth at the outboard ends of the bracket for the horizontal bolt.
Width at the ends of the square tubing where the attachment brackets are welded on.
Overall width
carriljc (12-15-2021)
#39
