Brake lights dont work. HELP!!
My brake lights do not come on.
1. The tailights work when the parking or front headlites are on, but the brakelights do not. With parking lights or front headlights off, brake lights will not come on when brake are applied. So it seems I have a problem somewhere in the breaklight switch circuit. Turn signals work fine wether headlites are on or not
I disconnected the brake light switch, and found it works fine thru a continuity check.
Now let me add this before the no brake light thing. 2 weeks ago, my drivers side outboard tailight would go dim if the headlites were on, and I applied the brakes. Just by chance, I was checking that brake tail/light housing this Saturday, and I accidentally grounded it against the rear bumper, a viola!, it worked fine, which makes the problem a poor ground. So I grounded it from the rear of the tailite housing to the frame, it worked fine. I didnt drive it anywhere afer this
So the next day, I walk out, and apply the brakes, and only the drivers side brakelights go on! Passenger side has tailites, but no brakelights!
Then magically, it progressed to no brake lights at all. Now I have just tailights if the headlites or parking lights are turned on. Turn signals work fine wether headlites are on or not. No brake lights at all
Man, my wiring under the dash that feeds the brake light switch circuit is so patched up with inproperly colored wires, there is no way I can trace where the problem lies
I beleive its a ground problem. But I have cleaned all ground straps, tailite housing grounds, etc, etc...........
One problem lies is that the wiring chart (Lectric Limited Laminated Poster)I have is very user unfriendly.
Could someone draw up a simplified (very simplified) wiring diagram (on power point maybe)that shows a simple brake/tailight circuit, that would show:
1. From power source to brakelight switch.
2. From brakelight switch to the 4 tailites/brake light housings, and to ground
(Remember, in my year (1968), back up lights are NOT in the tailight assemblies so I dont need the back up lamp circuit).
If you would please send to melvinjo@soc.mil
I may have to just compleley rewire to whole circuit. Cant afford a new wiring harness, and I cant trace the wiring because its so pacthed up
From the brake light switch, your wiring should lead up and into to the steering column. The hazard warning and turn signal features are all included in the turn signal switch inside the column.
I am not sure how you are going to do this but if you could find another turn signal switch, just connect it in place of your current switch and see if things operate correctly. Otherwise, you should try checking continuity through the current switch.
Are you saying the turn signals a brake lights work together in the same circuit?
If you can, please send a diagram. I really beleive Il have to wire this back up on my own
Ill try disconneting the harness as you said. I beleive I did that once by mistake, and they still didnt work. But Ill try again
In its neutral position (signals off), the turn signal switch allows current to flow through the brake switch to the bright filament(s) (which are also used for the turn signals) when you step on the brake. When the turn signal switch is "on" (left or right turn position), the turn signal switch "de-selects" the brake light circuit and activates the turn signal circuit through the flasher. So... the turn signal switch can cause the brake lights to fail. Check the actual brake light switch (at the brake pedal ) first.
Tom
Looks like I need to check my directional signal swicth, (sigh!)
[Modified by MNJack, 12:01 PM 10/28/2002]
Turn Signal Switch 1968 Telescoping Column 5698520 - Available through GM dealers - $86.00 List
Turn Signal Switch 1967 - Zip Products ES-210 - $49.50. According to their latest catalogue, I think this is the standard column switch.
I had a very similar experience. My problem was that my fuse was blowing any time that I hit the brakes. Everything else worked fine but not the brake lights. I spent hours trying to troubleshoot it (even w/ the help of the forum).
I finally gave up and brought it to the shop. It turns out the problem was as Jim Shea said. The turnsignal switch. Turned out I hide a short hidden in the column. They replaced the switch and VOILA... Brake lights.
Wish you luck!!
Tim M.
