Premium pump gas going to 20% ethanol?
read up on engine operation theory, and then two different cars I put DPFI on......first one was a '70 Lemans/GTO convertible....462" engine.....with carb it got about 12 mpg.....14 or so on the freeway not towing anything.....with the DPFI and a sorry old analogue open loop computer from a '79 Caddy 425 engine, it jumped to an easy 14+ around typical driving, and 18 on the freeway.....not towing, when towing a boat it got about 15-16 or so.....depending on how high it was flying......
Later on my '72 355 vette with muncie was getting ~12 around town 16 on the road...336 rear.....went to DPFI speed density like a '88-91 vette....got 24 on the road with the muncie......since then I have put in a 200 4r trans, and it's better yet on the road, but in fact I dunno how much due to driving habits....overall it's about 18 in mixed bag driving....
now to look at operational theory vs a carb, and it's a easy to see with my results....common sense 101, don't need more tests.....
I'll have to ask the mechanic again about these fuel changes he was talking about. He just volunteered the info when I mentioned doing a rebuild. Then another mechanic told me that 9.5 compression is about a high as you should go running on pump gas. I guess I'll just stay 10:1 and not worry about the crazy hear say. I used to hear some kind of knock or ping when going WOT with an 850 double pumper but might have been a timing thing. Thanks for all comments though.
An interesting discussion, to be sure. In my area, for a number of years, I could purchase 91 octane, "non-ethanol" gasoline, and that's all I used, both in my cars/trucks, as well as my yard equipment. But recently, the octane rating for this has dropped to 90, and I'm concerned about using it in the cars, now, as they all call for "premium" fuel. I can, however, still purchase 93 octane, 10% ethanol content "gas", and I'm confused as to what would be better for the cars. I know that the slightly lower octane rating won't matter to the garden tractor and lawn mower.
Dementer sole survivor
Received 6,383 Likes
2016 C3 of Year Finalist
I run 93 E10 with no detonation at 10.5:1, but I havent tried going lower because I'm lazy. You could try the non thanol and see if yo get detonation at your current timing setting, if you doo either drain the tank or back off the timing. If the price is right its worth it.
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes
Royal Canadian Navy
Here's an article for those who are concerned with using E10 in older cars:
https://www.hotrod.com/articles/mixi...-for-old-cars/
ignatz (11-17-2018)
