68 reverse light switch connect
Old Nov 20, 2018 | 09:16 AM
68 beginner's Avatar
68 beginner
Default 68 reverse light switch connect
does the reverse light switch on the 68 vette 4spd. connect to the rear body harness?
Old Nov 20, 2018 | 09:25 AM
chazde3's Avatar
chazde3
No, it connects to the engine bay wiring harness. Should be an L shaped connector with a pink and green wire. near the wiper motor.
Old Nov 20, 2018 | 12:04 PM
68 beginner
found the wires ...someone had cut them and taped over them on the dash harness
Old Nov 20, 2018 | 07:18 PM
68 beginner
I also installed new a/c harness...the dash harness has HEATER RESISTOR plug shown...if you have a/c does it not use HEATER RESISTOR connector...my wires didn't go to the heater switch at a/c control wheels....the plug connector wires were supposed to go to the fan switch....I untaped wire harness...they didn' go to anything...wire diagram shows wires go to heater fan switch...confusing
Old Nov 21, 2018 | 09:36 AM
sullyman56's Avatar
sullyman56
IIRC, on a non AC car the heater/ fan switch is part of the dash harness. On a car equipped with AC the AC / heater harness is used to connect to the switch. I recall removing a section of wire and plug and using it on the AC harness to complete the connection. I believe that this modification is shown in the AIM under section C60. The instructions for the modification came with my AC harness that I bought from Lectric limited and yours should have too. If you need it I can send you the page from the AIM.
Old Nov 22, 2018 | 09:55 AM
68 beginner
that explains why the wires were cut.....the new a/c harness from lectric limited does have a three prong plug that looks to connect to resistor on the a/c box itself..starting to make sense now...explain to me about AIM...I have an assy manual and a doc rebuild wiring diagram
Old Nov 22, 2018 | 10:03 AM
68 beginner
is Aim a different assy manual?
Old Nov 22, 2018 | 10:05 AM
68 beginner
by the way...thanks for your help..that was huge
Old Nov 22, 2018 | 12:33 PM
sullyman56's Avatar
sullyman56
It’s the same thing. It’s often referred to as the AIM or the Assembly Instruction Manual. I hope you get it sorted out. I started out with no wiring so I had to purchase all new harnesses. There was nothing in the engine bay either so I had to buy an engine and front lamp harness. Great learning experience and at least I know the wiring is new.
Old Nov 23, 2018 | 09:09 AM
68 beginner
my car is the sane...bought all new wiring....didn't have any to go by....you were a big help...thanks..Malcolm
To 68 reverse light switch connect
