Dash signal indicator not working
Old Nov 27, 2018 | 07:44 PM
Helibudi's Avatar
Helibudi
Cruising
Default Dash signal indicator not working
Hey guys, I posted earlier that my signal indicator lights would not work, advise was to replace bulbs, pulled dashboard and replaced all bulbs, the left one had started working intermittently, now all bulbs work accept right turn indicator, none of the bulbs I removed were burnt out. Any suggestions as to what I may need to check now?��
Sorry I forgot to put in here at first but working on a 1974 Stingray with this issue. Thanks for any input!,
Old Nov 28, 2018 | 01:54 PM
Peterbuilt's Avatar
Peterbuilt
Default Hi and welcome!
For the RIGHT dash light locate the HARMONICA connection and check at 'J' for 12 volts and a good connection on both of the DARK BLUE wires.
For the LEFT intermittent side check the light Blue wires.
Old Nov 28, 2018 | 06:53 PM
Helibudi's Avatar
Helibudi
Cruising
Thanks for all the advice, tested wiring and found that the right side bezel ( tach ) had a bad ground, not letting the bulb work
To Dash signal indicator not working
