Nevernight lighting info
Old Nov 28, 2018 | 05:05 PM
gwinnetts's Avatar
gwinnetts
1st Gear
Default Nevernight lighting info
Can anyone tell me what the fuse requirement is for the Nevernight headlamp harness conversion for a 74 Stingray. A customer brought one in and the Maxi fuse is missing. I called Speed Direct and they could not contact their tech to tell me what the fuse should be. I'm a new member, so I hope I'm posting in the correct forum. Also while I'm on the subject, this car has no dimmer switch on the floor. The wiring for the dimmer is connected to a circuit board. The lights will only change from high to low when the lights are turned off and then back on. Anybody have any ideas on this. Does not seem like a good way to control dimming.
Old Nov 28, 2018 | 06:55 PM
corvette74's Avatar
corvette74
The nevernight system takes a 40 amp fuse.
Dale
