79 Seat Removal question
Old Oct 29, 2002 | 10:41 AM
conway62's Avatar
conway62
Default 79 Seat Removal question
I want to remove the seat cusion on my 79 drivers seat to do some repair. Its not clear to me how remove the cusion.
Old Oct 29, 2002 | 10:48 AM
timbo79's Avatar
timbo79
Default Re: 79 Seat Removal question (conway62)
It is held on by two clips underneath. one on each side. the clips are like cables that are on the bottom of the seat and hook into the clips in the plastic bucket. When I removed them, I found it cheaper to buy some new seat foam from CCentral. At the same time I bought new covers and installed them.. was much cheaper than any other way. Back of seat is same set up. You will have to remove the top part of the seat to do this... bolts on the sides of the seats (3 on each side. Remove top, take off botom, remove 4 bolts holding it to rails, remove.. do the reverse on replacement.) If you do this, you can also clean uyp the buckets paint if chipped, dull or nicked and get some interior vinyl p[aqint. Mine was black, so it was simple, and at the same time you could do all of the "plastic" on the interior....
Old Oct 29, 2002 | 11:34 AM
conway62's Avatar
conway62
Default Re: 79 Seat Removal question (timbo79)
Thanks for the info. I will check it out tonight...
To 79 Seat Removal question
