ground problems
Old Dec 6, 2018 | 08:31 AM
weekshut's Avatar
weekshut
7th Gear
Default ground problems
where are the ground cables attached
Old Dec 6, 2018 | 09:17 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
There are several grounding points on a C3. What's your model year? The AIM shows the grounds.
Old Dec 6, 2018 | 09:31 AM
HeadsU.P.'s Avatar
HeadsU.P.
On some yrs, one grd cable comes outside of the bottom of the battery box and down to the frame.
Another is from the passenger side of the block, near the starter, to the frame, near the idler arm.
A super good ground is imperative on C3s. Grounding bolts must be shiny clean as are the terminal ends of the cable and the frame mount location itself. Like they say; 90% of electrical issues on C3s are poor GRDS.
Old Dec 6, 2018 | 09:53 AM
weekshut's Avatar
weekshut
7th Gear
I'm restoring a 1974 convertible, I attached a cable from the front left body mount to the frame, but still have to ground the blower motor to get it to work. I assume there are more grounds.
Old Dec 6, 2018 | 11:16 AM
lakerider57's Avatar
lakerider57
I think most of these are applicable to your '74:
- drivers side #1 mount to frame
- driver side on frame rail (just in front of gas tank) ground wire (16g blk) from rear harness + ground wire coming from led fog light
- rear light harness - rear crossmember
- at least one in the instrument panel i think it was by the headlight switch
- ground strap at the #4 mount on the driver's side
- rear area behind the bumpers in the middle of the frame connector above the spare tire carrier
- passenger side "engine" mount to frame
- Above the horn and vac relays for the headlights (near the tip of the hood you can see the radiator support brace) ground cable from front wire harness + ground cable from lamp harness
- antenna mounting plate to the frame
- battery to frame behind drivers seat (there is a star washer underneath the eye connection, diff. crossmember)
- left front hinge pillar
- on tranny case coming from the starter wiring loom
- ground to gas sender unit (18g blk)
Richard
Old Dec 6, 2018 | 11:51 AM
derekderek's Avatar
derekderek
Just think of this car as a boat. every single thing that is not mounted to metal has to be grounded separately. All the lights that are in the fiberglass body have to have a ground wire run to the frame. Or into a ground in the harness. And then you need the really big ground for the starter amps. I don't feel that **** go from the engine to the frame and the frame to the battery that's four separate points of possible loss of ground path. You should run a separate ground from the negative of the battery terminal to the engine block itself.
Old Dec 6, 2018 | 12:42 PM
Hammerhead Fred's Avatar
Hammerhead Fred
The blower motor and wiper motor are grounded via a ground wire that runs along the firewall harness and connects/grounds to the large retaining bolt at the starter.
Old Dec 6, 2018 | 01:41 PM
weekshut's Avatar
weekshut
7th Gear
Wow, thanks alot.
weekshut's Avatar
weekshut
7th Gear
Thanks for the info, very much appreciated.
Old Dec 6, 2018 | 01:43 PM
weekshut's Avatar
weekshut
7th Gear
Thanks for the info, very helpful.
Old Feb 13, 2020 | 04:48 PM
SwampeastMike's Avatar
SwampeastMike
And yes, the strange things happening when you turn on the headlights brings high suspicion on the front lamp harness grounds. I was able to access the one on the driver lower radiator support by removing the driver turn signal and using a wild combination of universal joints (2 of them), wobble extension and regular extensions. It also took a helper with reasonably small hands to guide the socket onto the bolt head. The bolt head is reasonably easy to see it's just a royal pain to get any tool on it.
Old Feb 13, 2020 | 07:09 PM
lionelhutz's Avatar
lionelhutz
Front lights and rad support are grounded by a wire connected to the alternator case.
To ground problems
