2 weeks ago...I found fuel leaking at the top of the carb,between the top plate and the main body gasket. I had it rebuilt and it's leaking again I brought it back to the shop and I found the problem, the top plate is warped side to side and front to back ~.040", what suggestions do you guys have? I'm leaning towards a new carb and intake, but would like to bolt on and go.If this was your problem how would you handle it.
tia.
Tom
Hmm, I just started a post about my air horn "swelling". If I wouldn't have seen it with my own eyes, I'd say that the warping would have to be due to over-torquing the air horn bolts, but now I'm not too sure.
overtorqued bolts I can understand created the problem and replacement is necessary, what should I replace the carb w/ or can I buy the just top plate :confused:
can someone e-mail me w/ summit's website link? I'm not sure if they are a supporting vendor so I don't want to rattle any cages.
tsks2001@msn.com
thanks,
Tom
